very simple question, plz I need the answer
Discussion in 'General Electronics Chat' started by fankoushat, Mar 28, 2010.
  1. fankoushat
    Mar 8, 2010
    17
    Hi guys,
    Consider the following circuit:
    http://www.postimage.org/image.php?v=gxFeffA
    V source , connected in series with resistor R , and open circuit.
    what is the voltage dropped between the open circuit terminals?
    equal to V source, or equal to V source - V dropped on R?
    Thanks alot
  2. dsp_redux
    Apr 11, 2009
    182
    5
    I don't see any circuits...?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There is no current in the circuit, so there is no drop across the resistor.
  4. dsp_redux
    Apr 11, 2009
    182
    5
    V=R*I
    If I=0A from the open circuit, V=0V. Same thing beenthere said.
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    But voltage between the open circuit terminals is equal Vsource
  6. fankoushat
    Mar 8, 2010
    17
    thanks johny, but why people say " the inductor at the beginning of connecting it with a dc source, will have voltage difference equals to V source - V dropped on R, because it is considered as open circuit".
    So voltage difference measured between the two open circuit terminal will be the same as V source.
  7. dsp_redux
    Apr 11, 2009
    182
    5
    When you do a DC analysis, you can consider capacitors as "open circuit" and inductors as "short circuit". There is no voltage drop in a short circuit. DC voltage is considered as a "0 frequency" or 0Hz. Impedance of a capacitor is X_C = \frac{1}{2\pi f C}. If you take f\rightarrow 0, X_C=\infty hense the capacitor considered as an open circuit. For the inductor X_L = 2\pi f L. X_L = 0 when f=0. It is considered as a short circuit.
  8. redlight000
    Member
    Feb 26, 2010
    66
    Hi dsp,
    Just asking how do you get those electronic equations on the post? are they built in this actual forum?? or you got a special program to do it??
    Why I ask I've got a few maths questions to ask..
    many thanks
    from
    redlight000
    :D
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
