Was looking for ideas on the simplest way to indicate that a 12V Lead Acid battery has reached a low level, somewhere between 12.2V -12.4V. In other words, a low voltage dectect circuit. The one real stipulation is that it must run off the battery itself.
Perhaps using a 9V zener to power a micropower comparator and a reference diode. A voltage devider off the battery would be the other comparator input.
The output would drive either an LED or small peizo.
Your thoughts!?
Your thoughts!?
