Very simple digital clock
Discussion in 'Homework Help' started by hamad, Jan 8, 2010.
  1. hamad
    Jan 8, 2010
    5
    Hai all; i am new here and find it really useful to visit the forums.
    I want to make a very simple digital clock (displays only mins and seconds)+ stopwatch project.
    Can any of u people plz help me out by giving circuit diagram or some guideline
    thanks all
  2. Boo
    Member
    Oct 27, 2009
    40
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. DigitalLogician
    Dec 20, 2009
    5
    Is this a software project or a digital system project? If it's software, what language are you using? if it's digital system and you need a refresher, start with the interactive circuits on http://www.teahlab.com/; you can play with the circuits or what the short videos.
    Be a bit more specific. You know more about your project than the rest of us: so share a little.
    Good luck
  5. hamad
    Jan 8, 2010
    5
    ^^^it is a digital system project;that is i have to buy IC'S and breadboard to make it
  6. Dalaran
    Dec 3, 2009
    168
    When you say "I have to buy IC's and breadboard to make it" it sounds like a homework project... is it or is it just for fun?
    Cheers.
  7. hamad
    Jan 8, 2010
    5
    actally making this clock and showing it to the instructor has 10% weightage in the final result.u may call it a graded homework :)
  8. DigitalLogician
    Dec 20, 2009
    5
    You really don't want to build this from scratch. Even a simple toggle flipflop may take 15 mins to build if you know what you are doing (http://www.teahlab.com/multivibrators/toggle/tjksrmasterslaveff.html).
    Now ICs come at all levels of complexity; so we need to know how much work your professor expects from you.
    If you really have to build this yourself, then the toggle flipflop can count your seconds for you for example. And you can use a network of multivibrators (http://www.teahlab.com/multivibrators/multivibrator.html) to correlate your minutes to 60 seconds.
    You could also buy multipliers (or ALUs), but multipliers take a lot of time to build if you have to use basic gates. Or you can buy full-adders (http://www.youtube.com/watch?v=oObT4dIZ9xg) to create your multipliers. The possibilities are many. So tell us, how much of the work is your professor expecting to be really yours?
  9. hamad
    Jan 8, 2010
    5
    ^^professor demands not so much work.
    ok now i have found the things to be used
    1) 555 timer
    2) variable resistance
    3)7 segment(*4)
    4)7447 decoder
    5)74192 (*4)
    6) breadboard
