VERY simple dc Q
Discussion in 'General Electronics Chat' started by daml, Jan 20, 2007.
  1. daml
    Jan 20, 2007
    ok my source is 12 - 14vdc and i need it to be 5vdc. what resister value in ohms do i need to accomplish this and what formula is used to figure out the correct solution. second (mainly just a refresher Q) if i put a 1.5 amp fuse in line of a circut which is 25 amps, will only 1.5 amps pass through the fuse and pop only if the unit being powered up attempts to draw more than 1.5 amps? sorry if the questions seem very novice, but i am a novice to this and eager to learn.
    Dave
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Re: first question:
    12v-5v is 7v, so your resistor must drop 7vdc.
    If you know how much current your circuit will draw at 5vdc, then you can use Ohm's law: 7v divided by current in amperes = your required resistor value. If you know your circuit resistance, then you can use algebra: Rd=Rc(7/5).
    Or you could use a fifty cent voltage regulator: http://www.fairchildsemi.com/ds/LM/LM7805.pdf
    Re: second question:
    The fuse will only blow if the circuit draws more current than the fuse is rated for.
  3. fanie
    Jan 20, 2007
    63
    Hi Daml
    You will need a regulator to bring the 12 to 24V down to 5V !
    The fuse rating is just what it say - it will blow and go open circuit if you exceed it's rated current, it's used for overcurrent protection and not regulation.
    I would highly recommend you check out a few of the online electronic courses so you get a basic idea - else it may cost you and create a health hazard !
  4. daml
    Jan 20, 2007
    ok so if i did my math right, i would need a 4.66666666666666666667 ohm dc resistor at 12vdc and a 6 ohm dc resistor at 14vdc to reach my desired current of 5vdc @ 1.5a. please correct me if im wrong
  5. n9352527
    Oct 14, 2005
    1,198
    Resistor would only work if the circuit drew constant current. Further, have you calculated the resistor power rating? Or the heatsinking required for a linear 7805?
  6. fanie
    Jan 20, 2007
    63
    Dave,
    If you say what the 5V is for we may be able to give you better advice.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The problem with resistive dividers is that the solution only works for one current draw - there's no load regulation. Using a 45 cent 7805 regulator is a better way to go.
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    1.5 Amp?!
    Forget what I said earlier. Use an LM350 instead. And a heatsink.
  9. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    You'd need a hideously expensive resistor. One made from wire wound on a ceramic core about a foot long. :p
    Get an LM7805 and be done with it. :)
  10. daml
    Jan 20, 2007
    First off i'd like to thank you all for your helpful input. New problems though... The LM7805 will not handle the required 1.5a rating. but i found an adjustable regulator, the LM317T. Below is a diagram of how i need to wire it up but there are obvious holes that are critical to get the output at 5vdc with 14vdc input. if someone could fill in the Blanks (R1 & R2) or provide a formula that would help me fill in the blanks i'd be estatic!
    Thanks again for your time and effort!!
  11. daml
    Jan 20, 2007
    ok nevermind. with some extensive research i found this:
    which has all the numbers i need. If i have anymore Q's ill be sure to post here!!
  12. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Vout=1.25v(1+R2/R1) just like it says in the image you posted...
    So: 5v=1.25(1+R2/R1)=1.25+1.25(R2/R1)
    And: 5v-1.25v = 3.75v = 1.25(R2/R1))
    Therefore: 3.75/1.25 = 3 = R2/R1
    In other words, any set of resistors with R2 being three times R1's value will be dandy. This is why the second image you posted has that ratio of resistors. (720/240 = 3)
