Very simple C syntax question
Discussion in 'Programmer's Corner' started by count_volta, Feb 8, 2010.
  1. count_volta
    Thread Starter Active Member
    Feb 4, 2009
    435
    24
    Okay so I have an assignment to write some mips assembly code from C code. I sorta forgot my C and just trying to remember it.
    My question is about syntax. In fact my textbook used incorrect syntax, and so its a little hard for me to understand what this code is doing.
    Here is the code the textbook gives. This is a function, subroutine.
    Code ( (Unknown Language)):
    1.  int find( int a[], int n, int x)
    2. {
    3.     int i;
    4.
    5.     for (i=0; i!=n; i++)
    6.         if(a[i]==x)
    7.
    8.                      return i;
    9. return -1;
    10.
    11.
    12. }[/i]
    There are obviously curly brackets { } missing in the if statement. Thus I have no clue what this code is supposed to do and when. I mean when does it return i, and when does it return -1?
    Obviously I need to understand the code if I am to turn it into mips. Can someone please help? Thanks guys.
  2. indianhits
    Jul 25, 2009
    86
    the program is correct there are no errors
    first it loops from i=0 to i=n along with the looping it checks for whether the array has the value of x if the array has the value of x then it returns the value i
    but if loop keeps on incrementing and the array doesn't have the value equal to x then the loop ends and the function returns -1
    i.e if array has the value of x then it returns i but if it doesn't then it returns -1
  3. mik3
    Feb 4, 2008
    4,846
    63
    a[] is an array and the for loop compares some values of the array until i does not equal (!=) n.
    Then I guess, it checks a==x and if this is true it returns i.
    Otherwise, it will reutrn -1. I think the book forgot the else statment which comes after the if.
  4. count_volta
    Feb 4, 2009
    435
    24
    Yea its definitely missing an else. Also shouldn't there be curly brackets? Syntax is there for a reason. The absence of curly brackets means the program does something entirely different.
  5. mik3
    Feb 4, 2008
    4,846
    63
    Well, I think curly brackets should be included for the for loop. For the if statement they are not necessari if there is just one instruction after the if statement. Also, I thought it better and the else statment is not really needed. This becuse if the if statement is true then it will return i and the subroutine will end. Otherwise, it will not execute return i but it will execute return -1 because it continuous with the next instruction.
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Curly braces are only required when the if-part or the else-part consist of a compound statement. A compound statement is semantically the same as the single statement when there are no curly braces.
    As a matter of style I ALWAYS use the curly braces for the case where I come back to a piece of code six months later and decide that a single statement really needs to be two or three statements.
  7. indianhits
    Jul 25, 2009
    86
    The function only returns i when a==x hence
    if there is an else then it will check only for i=0 and ends the function
    the above program is correct
    like for example this is not correct
    int i;
    if(a==x) return i;
    else return -1;
    //it loops only for i=0 and returns depending on the if condition
  8. count_volta
    Feb 4, 2009
    435
    24
    So the else basically says to not increment i by 1, and just exit the loop? That is weird and tricky. And you know what, I don't remember learning about such things properly in my C course.
    Can you guys suggest somewhere I can read about proper C condition statement syntax and how it effects what the program does?
  9. count_volta
    Feb 4, 2009
    435
    24
    By the way, my professor replied and said that this means the same thing as what I wrote in my first post,
    2. {
    3.     int i;
    4.
    5.     for (i=0; i!=n; i++){
    6.         if(a[i]==x){
    7.
    8.                      return i;
    9. }
    10. }
    11. return -1;
    12.
    13.
    14. }[/i]
    Umm, I don't think thats right. Isn't this positioning of the curly brackets saying, return i, if a == x. Then once you exit the for loop return -1. Just the action of exiting the for loop means to return -1.
    That sounds weird. Is that what the code in my first post does also?
  10. mik3
    Feb 4, 2008
    4,846
    63
    int find is a subroutine and the return instruction ends the subroutine. Thus, it will not execute the return -1 if a==x.
  11. indianhits
    Jul 25, 2009
    86
    both are same even if you put curly brackets or not
  12. count_volta
    Feb 4, 2009
    435
    24
    Okay I see, so if a == x, it will return i and go back to main program, but if a never equals to x, it will get to the end of the loop, jump out of the loop and return -1 and then go back to main program.
    Cool thanks. Now I can do that in mips assembly pretty easily.
  13. Harrington
    Dec 19, 2009
    86
    Hi this should give you a better idea of how this works
    I've rewritten the code for you so that it makes more sense then you can see what it does and hopefully get a better understanding
    #include <stdio.h>
    // declare global functions
    int find( int a[], int n, int x) ;
    int Array[] = { 1,3,5,4,10} ;
    // define the function in full here
    int i = -1 ;
    if(a==x){
    printf("Match found %d at index X = %d \n \n ",i,x);
    return i;
    } // end if
    }// end for
    if (i == -1 )
    printf("\n No Match found \n") ;
    return i;
    }// end function
    void main()
    char ch =' ';
    int x = 0;
    int n = 0 ;
    int match = 0 ;
    int j = 0 ;
    int flag = 1 ;
    printf("Enter q to quit or r to run \n\n");
    while(flag ==1){
    ch = getchar(); // get user input
    if(ch == 'r')
    printf(" Enter a value for x please followed by enter\n ") ; // prompt the user for input
    scanf ("%d",&n);
    printf("Enter a value for n please in the range of 0 to 5 followed by return\n");
    scanf ("%d",&x); // get user input
    match = find(Array,n,x); // simply return our value here
    printf("\n Array contents were \n");
    for( j = 0 ; j < 5 ; j ++)
    printf(" %d " ,Array[j]);
    printf("\n\n q to quit or r to run\n\n");
    if (ch =='q')
    flag = 0 ;
    } // end while
    printf("\n User typed q \n **** Quitting program **** \n" );
    }// end main method
