Very Simple Automatic 12 volts battery charger[Designed but need modification]
Discussion in 'The Projects Forum' started by ShayanFiroozi, Apr 21, 2016.
  1. ShayanFiroozi
    Nov 18, 2015
    41
    i have a very simple automatic 12 volts battery charger and working very well in a real application.
    it's perfect to charge 12volts 12AH SLA batteries.
    i didn't designed this circuit(as i'm pretty beginner in Electronics !) but i draw this circuit diagram from a real PCB
    now i need some modification , so hope experts help me :
    1-i need to add 2 LED's to this circuit first LED to indicates charging and second LED to indicates battery full charge
    2- when the main fails or unplug for a long time(for example 1 or 2 months !) the circuit will drain the battery , i think we can not use diodes because circit can not detect battery voltage (because diode will block battery current to come back to the circuit)so its automatic behavior will not work.
    any solution and modification will be appreciated.
    sorry for Bad English and Thank all of you.
  2. Alec_t
    Sep 17, 2013
    5,967
    1,135
    It's actually just a current-limited charger. As such it would need major modification to do what you are asking, since it has no way of determining the fully-charged state of the battery.
    This article is worth a read.
  3. ShayanFiroozi
    Nov 18, 2015
    41
    But I,m using this charger from 1 year ago to now!! Working well and it stops charging when battery get full
    Also I didn't designed this circuit,it,s a real circuit which I bought and then draw the schematic from it
  4. k7elp60
    Nov 4, 2008
    478
    69
    I can show you some modifications that will let you put a diode in the output so the charger will not discharge the battery if the AC fails, and a led will come on when the charge current decreases to an amount that the battery is charged. Also ad a LED to show power is on. Both of these modifications require a good DVM to make the adjustments. If you have a good digital volt meter let me know and I will post the circuit and the adjustment proceedure.
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    Alec isn't saying the circuit doesn't work, he is saying that it doesn't work the way you think it does, and that adding the LEDs you want is not a simple change.
    First, the circuit doesn't monitor the battery voltage directly. It makes an output voltage, measures the current, and adjusts the output voltage to keep the current at or below a 1.25 A. Adding an output diode in series with the output will not affect the current monitor circuit, and is the right way to prevent the circuit from discharging a connected battery when unpowered. This will decrease slightly the maximum output voltage, with will increase slightly the time it takes to recharge a dead battery. If this is a problem, R3 can be increased to compensate for the diode forward voltage drop. Your maximum output voltage now is 13.75 V, and the diode forward voltage will be around 0.8 V to 1.0 V at 1.25 A. Increasing R3 to 2.2K should work.
    To add the two LEDs, you need one or two comparators, depending on how accurate you want the LED indications to be. This will take some perf board, one chip, and about 8 to 10 resistors, capacitors, and diodes.
    ak
    Alec_t likes this.
  6. Dodgydave
    Jun 22, 2012
    5,141
    767
    Since its a constant voltage charger, i would use an op amp comparator like lm3914 to monitor the current change across the series resistor, as the current drops the battery voltage rises, simply adjust the comparator reference to suit the voltage range.
  7. ShayanFiroozi
    Nov 18, 2015
    41
    Thank all of you friends
    So I forget about Leds!!
    In current circuit can I attach my sla battery permanently?? Or it will damage my battery??
  8. Dodgydave
    Jun 22, 2012
    5,141
    767
    Leave it connected, it will just go into trickle mode.
  9. hp1729
    Nov 23, 2015
    2,085
    232
    Is the current limiting circuit really necessary? That is about what the LM317T is set to anyway, isn't it?
  10. k7elp60
    Nov 4, 2008
    478
    69
    I think a diode is needed on the output lead in series with the 3A fuse, this is in case the AC power goes off. Yes you would have
    increase the charge voltage to compensate for the drop across the diode. I would make the total value of R3 2.1K ohms.
    My calculations also the current output is 13.75V. This is within the range of float chargers for 12V lead acid batteries.
    I calculate the current limit to be very close to 1.4A. The LM317 data sheet read indicated the automatic current limit is
    between 1.5A and 2.2A.
    At the current charge voltage of 13.75V the battery is fully charged when the charging current drops to AH x .01. In this case
    with a 12AH battery that is 120Ma. So a led to indicate fully charged would be helpful.
  11. AnalogKid
    Aug 1, 2013
    4,685
    1,297
    Yes, but it is far more accurate, more repeatable across multiple builds, and adjustable by changing the shunt value. Overall, I'd keep it. Plus, there is the circuit mod where a higher value pot is placed across the shunt to make the current limit truly adjustable
    ak
  12. hp1729
    Nov 23, 2015
    2,085
    232
    Super! Thank you.
  13. ShayanFiroozi
    Nov 18, 2015
    41
    Thank you man !
    but i'm using this circuit for a battery backup so my 4.5 AH battery should always be connected to the this charger , also i'm using 600 milli ampere 16 volts transformer , is battery safe in such situation ?
    if not what is your suggestion
    thank you again :)
  14. Dodgydave
    Jun 22, 2012
    5,141
    767
    As long as the final output voltage is 13.8v across the battery its ok, the battery will limit its own current.
  15. ShayanFiroozi
    Nov 18, 2015
    41
    What guys think about this one ? i'm sure it's absolutely safe and industrial charger ? isn't it ?
  16. Dodgydave
    Jun 22, 2012
    5,141
    767
    Don't think it will work, the transistor will pull the adjust pin higher increasing the out voltage and current, i think the idea is to pull the adjust pin to ground to stop it.
    Also there is no protection if a 6v battery is put on 12v...
  17. ShayanFiroozi
    Nov 18, 2015
    41
    So it seems my first circuit is better for a battery backup , i'm going to make it
    but still afraid to plug a battery permanently to it , i know you told me there's no problem,but many others told me it's not safe and not efficient :(
    Dodgydave likes this.
  18. Dodgydave
    Jun 22, 2012
    5,141
    767
    ALL sla chargers are set to 13.8v for a 12v battery in intruder alarms, these are left on permanently connected to the battery, they wont blow up your battery.
  19. ShayanFiroozi
    Nov 18, 2015
    41
    Thank you for helping me sir
    but my first circuit in this Thread seems to be not automatic charger , so if i leave it permanently with battery , is it possible to be dangerous or reduce my battery life ?
    my battery is 2.2 AH 12 volts and i'm using 200 milliapmere 16volts transformer
    Thank you again , i'm really confused
  20. Dodgydave
    Jun 22, 2012
    5,141
    767
    I have lost the will to live.......
    roadey_carl likes this.
