Very newbie question
Discussion in 'General Electronics Chat' started by sebastian.conrad, Sep 22, 2012.
  1. sebastian.conrad
    Sep 22, 2012
    Hi
    I opened a DVD player that is not working and i discovered a damaged component, is like a big resistor but i dont know if it is a resistor or a capacitor. Please, can you help me to determine this? :confused:
    This is the component
    Thanks and best regards
    Sebastian
  2. electron_prince
    Member
    Sep 19, 2012
    93
    It is a resistor. do you see the color code. (the color bars)? replace it with a resistor which has the same color code.
    sebastian.conrad likes this.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
    It's probably the emitter resistor for that big black transistor right behind it which is probably shorted.
  4. sebastian.conrad
    Sep 22, 2012
    Great, I did not know that resistors could have that sustance inside. Thanks.
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    That substance is melted insulation. Either that or rust, if it's a wire-wound resistor.
    When you replace it, you not only have to make sure that the color codes are the same, but you also have to make sure it's has the same wattage rating. Try to match physical sizes and you should be okay.
    Oh, and the yellow-brown goo around the bottom is a thermal resistant adhesive. It did not come out of the resistor.
  6. Kermit2
    Feb 5, 2010
    3,845
    963
    Something else to be aware of.
    The laser diode in these cheap DVD players will burn out in short order. They do not last very long. Getting this repaired may be useless if the cause of the disorder is in the laser emitter circuit.
    Spend another $25 for a new one is about the best fix for a cheap DVD player.
