Hi, I have been trying to control a solonoid from a microcontroller. I have I suppose a very basic question:
the first is that I have been trying to test a simple MOSFET IRF510. How do I hook this up to a breadboard to make a simple on off switch using a 5V input to the Gate? I have hooked up a circuit with a resistor, led, and 9v battery through the source and drain pins, and have tried to switch it on with the 5v signal from a microcontroller. How should that be hooked to the gate to switch the MOSFET on? Or am I completely confused about how this should work?
