very low Voltage measurement
Discussion in 'General Electronics Chat' started by Lissajous, Jul 11, 2006.
  1. Lissajous
    May 17, 2006
    9
    For example I have a bench setup capable of measuring at the 0.5V range (resolution) and apparently I have to measure in the microvolt (or nano V ) range, how can I go about this? any work-around?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Your test equipment is not too good if you only have .5 volt resolution. Any meters I can think of have better resolution that that - is this a school problem? Any $9.95 meter beats that resolution.
    The quick cure is to spend some money on better metering. Kiethley makes some stuff that will easily go down to nanovolts, but the price will cross your eyes. For the microvolts range, any bench meter with 4 1/2 to 5 1/2 digits will easily get there.
    If you're at a university, check with the physics department for an old galvanometer - they usually will show microamps. The really classy ones need a scale on the wall of the room. They project a bright spot with an index bar in it. When your meter deflects 90 degrees over an arc with a radius of 15 feet, it's extremey precise.
  3. Lissajous
    May 17, 2006
    9
    thanks for your reply, beenthere! will "interface circuits" work? how about ICs? are there such?
    it's just something that crossed my mind while reading about test measurements......
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I don't follow you very well. Could you elaborate about your interface circuits and/or ic's?
  5. Polgi-Wan
    Member
    Sep 26, 2005
    11
    are you talking about amplifier (or attenuating) ICs? maybe the idea is amplifying the microvolt value into such state where the 0.5V range can measure the value.
  6. mozikluv
    Jan 22, 2004
    1,437
    hi,
    maybe this article can help you out
