very low temperature measurement
Discussion in 'The Projects Forum' started by Omega, Apr 20, 2009.
  1. Omega
    Feb 23, 2009
    15
    Hi every one I have to design electric measurement system to measure low temperature (mili to micro kelvin) any helpfull ideas?
    ω
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    What is the substance you are trying to measure the temperature of?
    Liquid helium is the coldest I know, that has a temperature of about 4.2 Kelvin.
    Greetings,
    Bertus
  3. Omega
    Feb 23, 2009
    15
    there is no specific material but I am trying to learn how I can measure this low temperature using electronics
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Measuring those low twmperatures is pretty hard to do.
    Some materials will become superconducting, so you can not measure the resistance anymore.
    An other practical problem : isolation material like a lot of plastics will break when moved because they have become very hard.
    Greetings,
    Bertus
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    This sounds like a physics problem. At that temperature range lots of really odd and exotic things happen, such as Bose-Einstein Condensates. I don't have a clue myself, a black body measurement perhaps?
  6. Skeebopstop
    Jan 9, 2009
    358
    I recently read about dark matter detectors. One of the two competing methods is to use NTC thermistors to measure for temperature fluxuations at temperatures of millikelvins. I do not know if they are measuring for 'realistic' temperatures, versus simple fluxuation anamolies due to an inbound particle collision. Regardless it is similar to what you seem to be after.
    Read up on them, maybe they hold the answers.
  7. KL7AJ
    Nov 4, 2008
    2,047
    295
    I would imagine that noise would be the easiest to measure with fairly common equipment.
    eric
  8. leftyretro
    Nov 25, 2008
    394
    Well there is a big difference between how one would measure temperatures with millikelvins resolution and how one would read absolute millikelvins range temperatures. Which one are you inquiring about?
    Lefty
  9. Omega
    Feb 23, 2009
    15
    I would like to measure absolute values of temperatures in the range of milikelvins down to microkelvins. I think NTC thermistors measures temperatures down to 10 Kelvin not less than that
  10. Skeebopstop
    Jan 9, 2009
    358
    The NTCs in use in the dark matter detectors operate at millikelvins. I cannot speak for their absolute measurement properties.
