Very fast VOX circuit?
Discussion in 'The Projects Forum' started by thestraniero, Apr 18, 2012.
  1. thestraniero
    Apr 18, 2012
    I need to design a VOX circuit that will open immediately when mic receives a sound and shut off when the sound stops. I have seen several VOX circuits, but they all seem to remain on for several seconds. I need one that shuts off faster. It's to make a puppet's mouth automatically sync to the sound of my voice.
    Kind regards!
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    I found this thread in the "completed projects" forum.
    As it says it is for completed projects.
    I moved it over here and made it visible.
    You could take a look at some sound to light circuits.
    Those are pretty direct responding to the incoming sound.
    Bertus
  3. #12
    Nov 30, 2010
    16,705
    7,358
    My first reaction is, show me the schematic and I'll show you which capacitor to change.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Even if you could build one I'm absolutely certain you will be unhappy with the results. The reason is that it will be subject to many false triggering events, both on and off.
  5. #12
    Nov 30, 2010
    16,705
    7,358
    As one that rarely questions the intent of the OP, my opinion is, "Let him experiment".
    The fact that this method is almost impossible to get correct won't stop me from pointing out which part controls the shut-off delay.
  6. R!f@@
    Apr 2, 2009
    8,793
    771
    What capacitor ? :confused:
  7. #12
    Nov 30, 2010
    16,705
    7,358
    The one that controls the shut-off time.
  8. R!f@@
    Apr 2, 2009
    8,793
    771
    Can a capacitor open and close a mouth?
  9. #12
    Nov 30, 2010
    16,705
    7,358
    Only if you connect it to a VOX circuit and then connect that to a servo motor.
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Even hobby level 2 transistor "vox" circuits can be tuned to have a fast on/off response. Usually by adjusting the size of a capacitor after the rectifier. I remember making one as a kid with a LED as the output, and with the right capacitor the LED would flash for every word spoken into the microphone.
    I'm sure if you build any simple vox circuit from the web you should be able to tune the response speed you need. :)
    #12 likes this.
  11. #12
    Nov 30, 2010
    16,705
    7,358
    Thanks for a vote of confidence from a person that has actually done this.
  12. KMoffett
    Dec 19, 2007
    2,586
    234
