very fast switching circuit
Discussion in 'General Electronics Chat' started by blessing mega, Dec 20, 2014.
  1. blessing mega
    Dec 20, 2014
    14
    Please I need a quick switching circuit acting like a change over
  2. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Two way switch from Home depot!! :rolleyes:
    Any more information?:confused:
    Max.
  3. blessing mega
    Dec 20, 2014
    14
    Yes such that it takes 1 manor seconds to change over
  4. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Do you mean 1 nanosecond?
  5. GopherT
    Nov 23, 2012
    6,321
    4,048
    NanoSecond, microsecond?
    Manor second?
    Maybe if you tell us what you want to switch over. Your bedroom lights, a little motor, a big motor, a high speed communications system.
  6. blessing mega
    Dec 20, 2014
    14
    An a.c induction motor
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    About how long the manor will last with this one tinkering!!!
    JWHassler and GopherT like this.
  8. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Many other factors involved, e.g. motor to load inertia ratio, this is where rate of acceleration/deceleration is required in order to calculate required capacity of supply etc.
    Max.
  9. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Another issues is how do you intend to slow the induction motor in order to reverse, external braking or by 'Plugging' the motor via power reversal?
    Actually plugging may achieve what you are looking for, all depends on the motor and application.
    http://www.electrical4u.com/induction-motor-braking/
    Max.
  10. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Why would you want to switch an induction motor in 1 whatsitsecond?
  11. MikeML
    Oct 2, 2009
    5,451
    1,066
    Would you want to reverse an induction motor in less than tens of seconds?
  12. blessing mega
    Dec 20, 2014
    14
    That is because I want to change it's power source
  13. blessing mega
    Dec 20, 2014
    14
    The main idea is this, one power source is use to power my a.c electric motor so I want to change to another power source so that the load the the electric motor is powering is not affected.
  14. MikeML
    Oct 2, 2009
    5,451
    1,066
    How big the motor?
    Motor is AC induction motor?
    What voltage?
    How long after the first power source is switched off will the motor spin due to inertia before you connect the second power source?
    If the first and second power sources are AC, are they the same voltage and phase at the moment of switchover?
    Methinks you are in way over your head...
  15. blessing mega
    Dec 20, 2014
    14
    Datz y I need a change over
  16. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    'Instant' reversal on a 3 phase induction motor is called 'plugging' the motor, how and when it is done depends on the HP and inertia involved, it can be very stressful on both motor and mechanics connected to motor.
    More is required in the way of motor size and/or gearing and mechanism involved.
    Max.
    cmartinez likes this.
  17. blessing mega
    Dec 20, 2014
    14
    It is a single phase motor
  18. wayneh
    Sep 9, 2010
    12,394
    3,246
    Read it again. I don't think he wants to reverse the motor, he wants to switch power sources seamlessly. Power ORing.
  19. MikeML
    Oct 2, 2009
    5,451
    1,066
    I'm done with this thread. I ask five simple questions, and get nothing that answers any of them in your reply!
  20. blessing mega
    Dec 20, 2014
    14
    So sorry, it is a 1.5hp a.c motor
