The Electrician
- Joined Oct 9, 2007
- 2,970
I fixed a typo in your post #1I'm a mechanical engineering student, so taking this course which has an electrical component is very hard to understand.
We were given a "black box" with four terminals sticking out of the top, and told to take the voltmeter and do a set of readings for each combination of terminals. 6 combinations total, and they are listed below:
Segment Resistance(Ω)
AB 500
AC 500
AD 11.4
BC 11.4
BD 499
DC 499
Then, the instructions are to find 6 equations that will give you the internal resistors. I have found 4 of those:
1/Rab= (1/AB ) + (1/ BC+CD+AD)
1/Rbc= (1/BC) + (1/ CD+AD+AB)
1/Rcd= (1/CD ) + (1/AD+AB+BC)
1/Rad= (1/AD ) + (1/ AB+BC+CD)
Now, I can't seem to figure out the last two? A classmate said that the last two had to do with if the arrangement inside is somehow diagonal. I don't understand how to get it from there.
I think I have just realized an assumption I have been making about your approach to the problem.
It appears in this post that the variables AB, AC, AD, BC, BD, DC are the resistances measured at the outside terminals of the black box, and the variables Rab, Rac, Rad, Rbc, Rbd, Rdc are the resistors internal to the box. Is this true?
If so, then you are following a wrong method in developing your equations. You have interchanged variables.
Your first equation should be 1/AB = (1/Rab) + (1/(Rbc+Rcd+Rad)) (still not quite right because you have ignored the diagonal resistors, but this shows the variables to use in which side of the equation)
You need to write equations showing the external measured resistances in terms of the internal resistors. Then you must solve those equations for the internal resistors in terms of the external measurements.
