Very basic power supply question
Discussion in 'Homework Help' started by Kara48, May 5, 2010.
  1. Kara48
    May 5, 2010
    5
    I will be taking a basic beginners electronics test, and I found a question on the internet that I don't understand. The question is: What size power supply would best be suited for a 12 VDC operation with a 0.2 amp current draw? The answer is 5 watts. How is this calculated?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    E X I = W
    Voltage X Current = Watts
    Kara48 likes this.
  3. retched
    Dec 5, 2009
    5,201
    313
    Ohms law is something you will need to become familiar with.
    Tattoo it in the brain. And remember WIRE.
    What is WIRE you ask? Well here you are:
    Kara48 and kingdano like this.
  4. Kara48
    May 5, 2010
    5
    I am familiar with OHMS law, but in this problem, E x I = W which calculates as 12 x .2 = 2.4 not the answer of 5 which is the answer stated on the practice test. Maybe the practice test answer is in error? Thanks for your help and input.
  5. CoolBeer
    Mar 29, 2010
    40
    6
    In my opinion it's a badly formulated question, one could probably make a case for "best" in a economic view or "best" in a reliability view, or any other view for that matter.
    God knows how they got the 5W though, unless they are operating with a fixed efficiency ratio *shrug*
    Kara48 likes this.
  6. retched
    Dec 5, 2009
    5,201
    313
    Is there a preface to the question that says use a power supply rated twice your load?
    Or is there a multiple choice that said something like:
    a) 750mW
    b) 5w
    c) 925 degrees
    d) rice krispies
    If that was the case, It would be 5.
  7. Kara48
    May 5, 2010
    5
    Okay, I'll assume the practice test is in error and forget about that particular problem. Thanks!
  8. Kara48
    May 5, 2010
    5
    Retched: No, there isn't anything written about twice the load. I wrote the problem above as written on the practice test, so I think it is just incorrect after the responses I've received. Thanks for your input!!
  9. retched
    Dec 5, 2009
    5,201
    313
    Your welcome.
    And if you really get an Ohms Law tattoo, send me a pic. ;)
  10. Kara48
    May 5, 2010
    5
    Wow, an Ohms tattoo...that would be a conversation piece! Thank you for your help. Back to my studies.
