Greetings, I have been working on a permanent magnet alternator, axial flux configuration.
It has been configured with vertically staked stators and rotors. The vertical configuration that I am use requires ½ the magnets then the traditional fabrication method.
Example: 3 phase, 8 coils per phase
Traditional fabrication requires 64 magnets
Stacked Vertical fabrication 32 magnets
. What I am really trying to find out is does the pull force or flux density accumulate when the magnets are stacked in a vertical configuration even with the added air gaps?
