Thanks a lot.
I was working on a new code for universal shift register. Please have a look on the code. I don't know but its testbench doesn't work at all and I'm getting all these warnings. Could you please help me? Thank you.
I have already installed Xilinx on my other computer but I have never tried to use it for any code run and don't really how it works.I'm using ModelSim
Yes, I have also tried to fix it and it looks like I'm somewhat successful.Look at your waves and see what's happening. Don't just give up. I got your code to work by modifying the testbench.
I have only one more code to finish then I will be done so start using a new program at this stage doesn't make much sense. Anyway, thanks for the advice.PG1995, before you try to test any more circuits, you need to find out why verilogger isn't working for perfectly good code. It won't be possible to debug code if your simulator isn't working.
Rich (BB code):
/ 4-bit universal shift register
module universal_shift_register(data_out, MSB_out, LSB_out, data_in, MSB_in, LSB_in, s0, s1, clk, rst);
input [3:0]data_in; // 3210
input MSB_in;
input LSB_in;
input s0, s1, clk, rst;
wire [3:0]data_in;
wire MSB_in, LSB_in, s0, s1, clk, rst;
output [3:0]data_out;
output MSB_out;
output LSB_out;
reg [3:0]data_out;
assign MSB_out = data_out[3];
assign LSB_out = data_out[0];
always @(posedge clk) begin
if (rst==1) data_out <=0;
else case({s0,s1})
0: data_out <= data_out; //hold
1: data_out <= {MSB_in, data_out[3:1]}; //right, 01
2: data_out <= {data_out[2:0], LSB_in}; //left , 10
3: data_out <= data_in; // parallel, 11
endcase
end
endmodule
module testbench;
wire [3:0]data_out;
wire MSB_out;
wire LSB_out;
reg [3:0]data_in;
reg MSB_in, LSB_in, s0, s1, clk, rst;
universal_shift_register uni_reg(data_out, MSB_out, LSB_out, data_in, MSB_in, LSB_in, s0, s1, clk, rst);
always begin
#5 clk = 0;
#5 clk = 1;
#5;
end
initial begin
rst = 1;
#7 rst=0;
#7 s0=0; s1=0; //hold case
#7 s0=0; s1=1; MSB_in=1; //right
#7 rst=1;
#7 rst=0;
#7 s0=1; s0=0; LSB_in=1; //left
#7 rst=0;
#7 s0=1; s1=1; data_in=3; //parallel
#14 $finish;
end
endmodule
