Verilog question
Discussion in 'Programmer's Corner' started by Joe24, Sep 23, 2008.
  1. Joe24
    Thread Starter Active Member
    May 18, 2007
    52
    Ok, I have a piece of Verilog code that I want to use. But somethings are unclear to me. For example, consider the following small piece of code:
    parameter x = 5000;
    wire [16:0] y = (x << 20);
    Ok, so this is a simple example code that illustrates my question. Question is:
    How is x shifted to the left by 20? Would I have to convert 5000 from decimal to bits and shift left by 20 bit positions?
  2. roddefig
    Apr 29, 2008
    149
    Yes. However, you'll end up with all zeroes as your data type is only 17 bits wide.
  3. Joe24
    May 18, 2007
    52
    So the compiler I guess would automatically convert from decimal to binary?
    Where in contrast, in VHDL, we the programmers would have to explicitly force the conversion in the code. Ex.
    Singal X: Integer range 0 to 256;
    Signal Y: std_logic_vector( 7 downto 0);
    . // somwhere in between y gets assigned some binary value
    x <= to_integer( y);
    RIght??
  4. roddefig
    Apr 29, 2008
    149
    I'm not really familiar with VHDL, but I don't think it should matter. The actual representation of the number in FPGA is always binary (signed or unsigned).
