Verilog Prime number homework please help
Discussion in 'Programmer's Corner' started by Bobsons, Aug 21, 2014.
  1. Bobsons
    Aug 21, 2014
    9
    Hi all.
    I really need help with Verilog.
    Our lecturer has restricted to use if/else and etc.. We are allowed to use just AND OR NOT and etc logic gates.
    We are also restricted to use counters like n = n + 1 and supposed to make it with flip-flops
    Deadline: August 22, 2014 (11:59pm)
    The Prime Number
    A prime number (or a prime) is a natural number greater than 1 that has
    no positive divisors other than 1 and itself. A natural number greater than
    1 that is not a prime number is called a composite number. For example, 5
    is prime because 1 and 5 are its only positive integer factors, whereas 6 is
    composite because it has the divisors 2 and 3 in addition to 1 and 6.
    In this assignment, on the Verilog environment, you will design a prime
    counter counting between 1-63 and repeating 5 times by returning to the
    beginning. Your each code line must include an explanation line, and another
    something important is that your codes must be synthesizable.
    Im stuck at making counters because dont know Verilog well
    My code is:
    Code ( (Unknown Language)):
    1.
    2. module dff (Q,D, CK);
    3.     input CK,D;
    4.     output Q;
    5.
    6.     wire NM,NCK;
    7.     wire NQ,M;
    8.
    9. nand DN1 (NM,D,CK);
    10. nand DN2 (M,NM,CK);
    11. nand DN3 (Q,NQ,NM);
    12. nand ND4 (QN,Q,M);
    13. endmodule
    14.
    15. module tb;
    16.     reg D, CK;
    17.     wire Q;
    18.     dff p0(Q, D, CK);
    19.     //jkstruct m0(q, qn, t, cp);
    20.     initial begin
    21.         D = 0;
    22.         CK = 1;
    23.         #100;
    24.         $display(Q);
    25.         D = 0;
    26.         CK = 1;
    27.         #50
    28.         $display(Q);
    29.         D = 1;
    30.         CK = 0;
    31.         #50
    32.         $display(Q);
    33.         D = 1;
    34.         CK = 1;
    35.
    36.         $display(Q);
    37.         $finish;
    38.     end
    39. endmodule
    I cant even test my flip flop...
  2. tshuck
    Oct 18, 2012
    3,531
    675
    This is why you shouldn't wait until the project is nearly due before you start asking questions - ask them often and as soon as there is any confusion.
    Your professor wants you to design a counter with flip flops - this thread might help you with how to do that.
    Why can't you test your flip flop?
  3. Bobsons
    Aug 21, 2014
    9
    Well I have done all minor modules. just counter left. The problem is that I actually dont understand how to represent it in code. But I have build it on chips with wires and LEDs.
    I need a counter with reset on verilog. The modules must be done with logic gates. This is the problem for me
    I always get X from Q output... Whatever I do I get x
  4. tshuck
    Oct 18, 2012
    3,531
    675
    Code (Text):
    1. module dff (Q,D, CK);
    2.     input CK,D;
    3.     output Q;
    4.
    5.     wire NM,NCK;
    6.     wire NQ,M;
    7.
    8. nand DN1 (NM,D,CK);
    9. nand DN2 (M,NM,CK);
    10. nand DN3 (Q,NQ,NM);
    11. nand ND4 (QN,Q,M);
    12. endmodule
    The X means you have undefined signals at some point. Initializing values can help...
    Use an always block that makes Q <= D on each rising edge of the clock.
  5. Bobsons
    Aug 21, 2014
    9
    That is the problem. We are restricted to use always, <= , and etc in the modules.
  6. tshuck
    Oct 18, 2012
    3,531
    675
    Restricted to use means you can only use them - you seem to mean restricted from use.
    Are you sure this is the case in regards to the flip flop design? I can understand it at the counter level, but not the flip flop level.
    Why don't you list everything you can't use instead of telling us after the fact?
  7. Bobsons
    Aug 21, 2014
    9
    Our lecturer said that we are restricted to design the cirquit with if/else <= loops, and all the other high level programming ways.
    When I asked him the list of restrictions - he said "estricted to design the cirquit with if/else <= loops, and all the other high level programming ways." and left the class. When I went his office - he said same without any details...
    He just said to use logic gates otherwise we get 0 points...
  8. Bobsons
    Aug 21, 2014
    9
    I just need to make this flip flop to work. Im getting X as output. But how to set default value to reg without <=?
  9. tshuck
    Oct 18, 2012
    3,531
    675
    In your testbench, make sure you put
    1. initial
    2.    begin
    3.     D =0;
    4.     end
  10. Bobsons
    Aug 21, 2014
    9
    Done already. Not helped. Output is always X
  11. tshuck
    Oct 18, 2012
    3,531
    675
    Okay, have a look at your flip flop code. Draw it out from the Verilog. You'll find that NQ is not defined, yet is an input to a NAND gate... Your output cannot be determined because you have an indeterminate input.
  12. tshuck
    Oct 18, 2012
    3,531
    675
    Take a look at this, it shows how you can implement a D flip flop...
  13. Brownout
    Jan 10, 2012
    2,375
    998
    Try this:
    NOT N1(NQ, D)
    NAND DN2(M, NQ, CK)
    NAND DN3(Q, QN, NM)
    NAND DN4(QN, Q, M)
  14. Bobsons
    Aug 21, 2014
    9
    Thying to implement a JK flip-flop in Verilog but always get X output. My head is going to explode...
    Code:
    1.
    2. module jkff (q, j, k, clk);
    3.     input j, k, clk;
    4.     output q;
    5.     wire clkn, g1o, g2o, g5o, g6o, qn;
    6.
    7.     not n1(clkn, clk);
    8.
    9.     nand g1(g1o, j, clk, qn);
    10.     nand g2(g2o, k, clk, q);
    11.
    12.     nand g3(s, r, g1o);
    13.     nand g4(r, s, g2o);
    14.
    15.     nand g5(g5o, s, clkn);
    16.     nand g6(g6o, r, clkn);
    17.
    18.     nand g7(q, qn, g5o);
    19.     nand g8(qn, q, g6o);
    20. endmodule
    21.
    And a TestBench:
    1. module tb;
    2.     reg j, k, clk;
    3.     wire q;
    4.     jkff jk0(q, j, k, clk);
    5.     initial begin
    6.         j = 1;
    7.         k = 0;
    8.         #100
    9.         clk = 1;
    10.         #20
    11.         clk = 0;
    12.         #20
    13.         clk = 1;
    14.
    15.     end
    16.
    17. endmodule
    Used this picture to write code: http://www.indiabix.com/_files/images/electronics-circuits/jk-flip-flop.png
    The problem is in
    1. nand g7(q, qn, g5o);
    2.     nand g8(qn, q, g6o);
  15. Brownout
    Jan 10, 2012
    2,375
    998
    Try initializing clk to zero and make sure you declare r and s.
  16. Brownout
    Jan 10, 2012
    2,375
    998
    Oh, one more thing. Your flip-flop will start in an unknown state. You need a way to set or reset it to a known state.
    Add a reset wire to g4 and g8.
  17. Bobsons
    Aug 21, 2014
    9
    How to? Im newbie in Verilog....
  18. Brownout
    Jan 10, 2012
    2,375
    998
    Just make new ports for reset like you have for clk and d. Connect to the inputs like the other signals.
  19. Bobsons
    Aug 21, 2014
    9
    The problem is that I dont know why it is not working. New data is not assigning to FF at all
  20. Brownout
    Jan 10, 2012
    2,375
    998
    I can only suggest ways to get it to work. You have to try to implement them. Or not if you want to continue to flounder.
