Verilog Help
Aqual
Joined Nov 5, 2011
I have been working at this code for hours now and can't seem to figure out my mistake. Essentially, the code acts as a 4-bit binary to BCD converter. After the final value of each digit has been determined, it is sent to a module to print it out on a 7-segment display using cathode and anode. Behaviorally, the modules work fine. However, once translated, the code breaks down. A post-translation simulation reveals that "state" from the main module is being recognized as a 3-bit array, instead of 2. Any and all help is greatly appreciated.
Here is the main module
Rich (BB code):
module Binary_Display
    (input CLK_50M,
    input [7:0] switches,
    input reset,
    output [6:0] cathode,
    output [3:0] anode);
    parameter [1:0]     CLEAR = 2'b00,
                            SHIFT = 2'b01,
                            ADD_3 = 2'b10;
    wire mili_clk;
    reg [1:0] state, next = 0;
    reg [7:0] switch_temp, binary;
    reg [3:0] hundreds, tens, ones, hfinal, tfinal, ofinal;
    reg [3:0] shift_counter;
    Top_Module clock
    (.CLK_50M(CLK_50M),
    .reset(reset),
    .Milli_sec_clock(mili_clk));
    Display control
    (.clk_mili(mili_clk),
    .hundreds(hfinal),
    .tens(tfinal),
    .ones(ofinal),
    .reset(reset),
    .anode(anode),
    .cathode(cathode));
    always @ (posedge CLK_50M or posedge reset) begin
        if (reset) begin
            state <= CLEAR;
        end else if (switch_temp != switches) begin
            state <= CLEAR;
        end else begin
            state <= next;
        end
    end
    always @* begin
        next = state;
        case (state)
            CLEAR:    begin
                            switch_temp = switches;
                            shift_counter = 0;
                            hundreds = 0;
                            tens = 0;
                            ones = 0;
                            binary = switches;
                            next = SHIFT;
                        end
            SHIFT:    begin
                            hundreds = {hundreds[2:0], tens[3]};
                            tens = {tens[2:0], ones[3]};
                            ones = {ones[2:0], binary[7]};
                            binary = {binary[6:0], 1'b0};
                            shift_counter = shift_counter + 1;
                            next = ADD_3;
                        end
            ADD_3:    begin
                            if (shift_counter == 8) begin
                                hfinal = hundreds;
                                tfinal = tens;
                                ofinal = ones;
                                next = CLEAR;
                            end
                            else begin
                                if (hundreds > 4) begin
                                    hundreds = hundreds + 3;
                                end
                                if (tens > 4) begin
                                    tens = tens + 3;
                                end
                                if (ones > 4) begin
                                    ones = ones + 3;
                                end
                                next = SHIFT;
                            end
                        end
            default: next = CLEAR;
        endcase
    end
endmodule
here is the module for determining cathode and anode
module Display
    (input clk_mili,
    input [3:0] hundreds,
    input [3:0] tens,
    input [3:0] ones,
    input reset,
    output reg [3:0] anode,
    output reg [6:0] cathode);
    parameter [2:0]    state1 = 3'b000,
                            state2 = 3'b001,
                            state3 = 3'b010,
                            state4 = 3'b011,
                            state5 = 3'b100;
    reg [2:0] state, next;
    reg [3:0] T1;
    reg [6:0] temp1;
    always@ (posedge clk_mili or posedge reset) begin
        if (reset) begin
            state <= state1;
        end else begin
            state <= next;
        end
    end
    always@ * begin
        case (state)
            state1:    begin
                            cathode = 1;
                            anode = 0;
                            next = state2;
                        end
            state2:    begin
                            anode = 4'b1110;
                            T1 = ones;
                            case (T1)
                                0: temp1 = 7'b0000001;
                                1:    temp1 = 7'b1001111;
                                2: temp1 = 7'b0010010;
                                3:    temp1 = 7'b0000110;
                                4:    temp1 = 7'b1001100;
                                5:    temp1 = 7'b0100100;
                                6:    temp1 = 7'b0100000;
                                7: temp1 = 7'b0001111;
                                8: temp1 = 7'b0000000;
                                9: temp1 = 7'b0000100;
                                10: temp1 = 7'b0001000;
                                11: temp1 = 7'b1100000;
                                12: temp1 = 7'b0110001;
                                13: temp1 = 7'b1000010;
                                14: temp1 = 7'b0110000;
                                15: temp1 = 7'b0111000;
                            endcase
                            cathode = temp1;
                            next = state3;
                        end
            state3:    begin
                            anode = 4'b1101;
                            T1 = tens;
                            case (T1)
                            endcase
                            cathode = temp1;
                            next = state4;
                        end
            state4:    begin
                            anode = 4'b1011;
                            T1 = hundreds;
                            case (T1)
                            endcase
                            cathode = temp1;
                            next = state5;
                        end
            state5:    begin
                            anode = 4'b0111;
                            cathode = 1;
                            next = state2;
                        end
            3'b101:    next = state1;
            3'b110:    next = state1;
            3'b111:    next = state1;
            default: next = state1;
        endcase
    end
endmodule
and finally, here is a module that is used to generate a 1 millisecond clock
module Top_Module
    (input CLK_50M,
    input reset,
    output reg Milli_sec_clock);
    reg [14:0] counter = 0;
        if (reset) begin
            Milli_sec_clock <= 0;
            counter <= 1;
        end else begin
            if (counter == 25000) begin
                Milli_sec_clock <= ~Milli_sec_clock;
                counter <= 1;
            end else if (counter == 0) begin
                counter <= 1;
            end else begin
                counter <= counter + 1;
            end
        end
    end
endmodule
Is it possible for you to post some results? Simulation results? Explanation of 'the code breaks down' ?
I have a few comments though:
This is probably because it's using one-hot encoding by default. Most FPGA tools will do this because one-hot encoding is faster in FPGAs and it's practically free (FPGAs have loads of flip flops).
Also, un-synchronized asynchronous resets are discouraged in FPGAs. They are VERY rarely necessary.
Also, you have a lot of latches in this design (also poor FPGA design practice). Your output signals should all be assigned in every single state. The easy way to do that is with default assignments.
