Having trouble on how to start about this program:
The circuit asks to utilize a controller with an input called Start/Stop to control the process of data being read through three registers. If the input = 1 then the data processes through the shift register, and if equal to 0, then the process stops.
Data will be processed from:
-4 bit parallel load into shift register 1
-4 bit parallel transfer from register 1 to register 2
-4 bit serial transfer from register 2 to register 3 by shifting left to right
-4 bit serial transfer from register 3 to register 1 by shifting right to left
Assignment Attached. Any help and reference/explanations would be greatly appreciated! Thank You in Advance!
-PLe93
-PLe93
