verilog confusion
Discussion in 'Programmer's Corner' started by spookymulder, Aug 23, 2014.
  1. spookymulder
    Aug 23, 2014
    Hi everyone. New to the forum as well as pretty much any programming language stuff. Long story short, the question is:
    Write a Verilog module for the circuit F(X,Y)=Y+X'Y' using verilog primitives AND, OR and NOT.
    Took the lecture last semester. Not once did verilog even get mentioned so I'm trying to figure out what I can from my book. Not going so well. Most of the examples I've found out in the web are WAY too complex with very little explanation that makes sense to follow what's going on. This question is then followed up with drawing a timing diagram for the circuit which I think I may be able to figure out but not sure. Any help would be greatly appreciated.
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Look up structural verilog. Also, see the thread about Verilog prime numbers (just above this one) It contains some simple examples.
  3. tshuck
    Oct 18, 2012
    3,531
    675
  4. spookymulder
    Aug 23, 2014
    thanks tshuck. had a hard time finding simpler examples or better explanation of how this code is supposed to function.
  5. Brownout
    Jan 10, 2012
    2,375
    998
    If you want to check out the Verilog prime number thread, there is an example now that works (sort of, it's not exactly right, but now the data output pins of J-K flip-flop update correctly)
