Hi Everyone,
I am new to Verilog. I am trying to code a 1/2 rate convolutional encoder (http://en.wikipedia.org/wiki/Convolutional_code) in Verilog. I have the written the code and the test bench for it.
However, i am going wrong somewhere. Anyone's help would be greatly appreciated. Please try helping !!
Verilog code:
//1/2 rate convolutional code with 3 registers; polynomials being (1,1,1) & //(1,0,1)
module omencoder(out1,out2,in1,clk);
output out1, out2;
input in1,clk;
reg u0 = 1'b0 ,u1 = 1'b0 ,u2 = 1'b0 , temp_u0, temp_u1, temp_u2;
always @(in1)
begin
temp_u0 <= u0;
temp_u1 <= u1;
temp_u2 <= u2;
//I was facing a race condition. Hence tried to put delay statement.
#2 assign u2 = temp_u1;
$display("value of u2 = %b",u2);
#4 assign u1 = temp_u0;
$display("value of u1 = %b",u1);
#6 assign u0 = in1;
$display("value of u0 = %b",u0);
end
//using polynomials (1,1,1) & (1,0,1)
xor (out1,u0,u1,u2);
xor (out2,u0,u2);
endmodule
Testbench:
module stimulus;
reg clk;
reg in1 = 1'b1;
omencoder om1(out1,out2,in1,clk);
initial
begin
clk = 1'b1;
#50 in1= 1'b1;
#100 in1= 1'b0;
#150 in1= 1'b1;
#200 in1= 1'b0;
//the last 2 input bits are used to flush the registers.
#250 in1= 1'b0;
#300 in1= 1'b0;
#350 $finish;
end
initial
$monitor("output bit 1 = %b, output bit 2 = %b", out1,out2);
endmodule
Verilog code:
output out1, out2;
input in1,clk;
always @(in1)
begin
temp_u0 <= u0;
temp_u1 <= u1;
temp_u2 <= u2;
#6 assign u0 = in1;
end
xor (out2,u0,u2);
endmodule
Testbench:
module stimulus;
reg clk;
reg in1 = 1'b1;
initial
begin
clk = 1'b1;
#50 in1= 1'b1;
#100 in1= 1'b0;
#150 in1= 1'b1;
#200 in1= 1'b0;
#250 in1= 1'b0;
#300 in1= 1'b0;
#350 $finish;
end
initial
endmodule
