hi friends
anybody can explain how to write a verilog code for analog to digital converter
// 16-bit Analogue-Digital Converter
// | Copyright 1996 DOULOS |
// | designer : Tim Pagden |
// | opened: 7 Jun 1996 |
`timescale 1 ns / 1 ps
module ADC_16bit (analog_in,digital_out);
parameter conversion_time = 25.0, // conversion_time in ns
// (see `timescale above)
charge_limit = 1000000; // = 1 million
input[63:0] analog_in;
// double-precision representation of a real-valued input port;
// a fix that enables
// analog wires between modules to be coped with in Verilog.
// Think of input[63:0] <variable>
// as the equivalent of MAST's electrical.
output[15:0] digital_out;
reg[15:0] delayed_digitized_signal;
reg[15:0] old_analog,current_analog;
reg[4:0] changed_bits;
reg[19:0] charge;
reg charge_ovr;
reg reset_charge;
/* SIGNALS:-
analog_in = 64-bit representation of a real-valued signal
analog_signal = real valued signal recovered from analog_in
analog_limited = analog_signal, limited to the
real-valued input range of the ADC
digital_out = digitized 16bit 2's complement quantization of analog_limited
/* function to convert analog_in to digitized_2s_comp_signal.
Takes analog_in values from (+10.0 v - 1LSB) to -10.0 v and converts
them to values from +32767 to -32768 respectively */
function[15:0] ADC_16b_10v_bipolar;
parameter max_pos_digital_value = 32767,
max_in_signal = 10.0;
reg[15:0] digitized_2s_comp_signal;
real analog_signal,analog_abs,analog_limited;
integer digitized_signal;
begin
analog_signal = $bitstoreal (analog_in);
if (analog_signal < 0.0)
begin
analog_abs = -analog_signal;
if (analog_abs > max_in_signal)
analog_abs = max_in_signal;
analog_limited = -analog_abs;
end
else
begin
analog_abs = analog_signal;
analog_limited = analog_abs;
end
if (analog_limited == max_in_signal)
digitized_signal = max_pos_digital_value;
else if (analog_limited == -max_in_signal)
digitized_signal = -max_pos_digital_value;
else
digitized_signal = $rtoi (analog_limited * 3276.8);
digitized_2s_comp_signal = digitized_signal;
ADC_16b_10v_bipolar = digitized_2s_comp_signal;
end
endfunction
/* This function determines the number of digital bit changes from
sample to sample; can be used to determine power consumption if required.
Task power_determine not yet implemented */
function[4:0] bit_changes;
input[15:0] old_analog,current_analog;
reg[4:0] bits_different;
integer i;
begin
bits_different = 0;
for (i=0;i<=15;i=i+1)
if (current_analog != old_analog)
bits_different = bits_different + 1;
bit_changes = bits_different;
end
endfunction
/* Block to allow power consumption to be measured (kind of). Reset_charge
is used to periodically reset the charge accumulated value (which can be
used to determine current consumption and thus power consumption) */
always @ (posedge reset_charge)
begin
charge = 0;
charge_ovr = 0;
end
/* This block only triggered when analog_in changes by an amount greater
than 1LSB, a crude sort of scheduler */
always @ (ADC_16b_10v_bipolar (analog_in))
begin
current_analog = ADC_16b_10v_bipolar (analog_in); // digitized_signal
changed_bits = bit_changes (old_analog,current_analog);
old_analog = current_analog;
charge = charge + (changed_bits * 3);
if (charge > charge_limit)
charge_ovr = 1;
end
/* Block to implement conversion_time tpd; always block use to show
difference between block and assign coding style */
always
# conversion_time delayed_digitized_signal = ADC_16b_10v_bipolar (analog_in);
assign digital_out = delayed_digitized_signal;
endmodule
All rights goes to
http://www.doulos.com/knowhow/verilog_designers_guide/models/analogtodigital_converter/
Rich (BB code):// 16-bit Analogue-Digital Converter // // +-----------------------------+ // | Copyright 1996 DOULOS | // | designer : Tim Pagden | // | opened: 7 Jun 1996 | // +-----------------------------+ `timescale 1 ns / 1 ps module ADC_16bit (analog_in,digital_out); parameter conversion_time = 25.0, // conversion_time in ns // (see `timescale above) charge_limit = 1000000; // = 1 million input[63:0] analog_in; // double-precision representation of a real-valued input port; // a fix that enables // analog wires between modules to be coped with in Verilog. // Think of input[63:0] <variable> // as the equivalent of MAST's electrical. output[15:0] digital_out; reg[15:0] delayed_digitized_signal; reg[15:0] old_analog,current_analog; reg[4:0] changed_bits; reg[19:0] charge; reg charge_ovr; reg reset_charge; /* SIGNALS:- analog_in = 64-bit representation of a real-valued signal analog_signal = real valued signal recovered from analog_in analog_limited = analog_signal, limited to the real-valued input range of the ADC digital_out = digitized 16bit 2's complement quantization of analog_limited */ /* function to convert analog_in to digitized_2s_comp_signal. Takes analog_in values from (+10.0 v - 1LSB) to -10.0 v and converts them to values from +32767 to -32768 respectively */ function[15:0] ADC_16b_10v_bipolar; parameter max_pos_digital_value = 32767, max_in_signal = 10.0; input[63:0] analog_in; reg[15:0] digitized_2s_comp_signal; real analog_signal,analog_abs,analog_limited; integer digitized_signal; begin analog_signal = $bitstoreal (analog_in); if (analog_signal < 0.0) begin analog_abs = -analog_signal; if (analog_abs > max_in_signal) analog_abs = max_in_signal; analog_limited = -analog_abs; end else begin analog_abs = analog_signal; if (analog_abs > max_in_signal) analog_abs = max_in_signal; analog_limited = analog_abs; end if (analog_limited == max_in_signal) digitized_signal = max_pos_digital_value; else if (analog_limited == -max_in_signal) digitized_signal = -max_pos_digital_value; else digitized_signal = $rtoi (analog_limited * 3276.8); digitized_2s_comp_signal = digitized_signal; ADC_16b_10v_bipolar = digitized_2s_comp_signal; end endfunction /* This function determines the number of digital bit changes from sample to sample; can be used to determine power consumption if required. Task power_determine not yet implemented */ function[4:0] bit_changes; input[15:0] old_analog,current_analog; reg[4:0] bits_different; integer i; begin bits_different = 0; for (i=0;i<=15;i=i+1) if (current_analog != old_analog) bits_different = bits_different + 1; bit_changes = bits_different; end endfunction /* Block to allow power consumption to be measured (kind of). Reset_charge is used to periodically reset the charge accumulated value (which can be used to determine current consumption and thus power consumption) */ always @ (posedge reset_charge) begin charge = 0; charge_ovr = 0; end /* This block only triggered when analog_in changes by an amount greater than 1LSB, a crude sort of scheduler */ always @ (ADC_16b_10v_bipolar (analog_in)) begin current_analog = ADC_16b_10v_bipolar (analog_in); // digitized_signal changed_bits = bit_changes (old_analog,current_analog); old_analog = current_analog; charge = charge + (changed_bits * 3); if (charge > charge_limit) charge_ovr = 1; end /* Block to implement conversion_time tpd; always block use to show difference between block and assign coding style */ always # conversion_time delayed_digitized_signal = ADC_16b_10v_bipolar (analog_in); assign digital_out = delayed_digitized_signal; endmodule
by Aaron Carman
by Jake Hertz
by Aaron Carman
