Verifying memory size of logic analyzer?
Discussion in 'Embedded Systems and Microcontrollers' started by spinnaker, Jan 28, 2014.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,103
    1,192
    I am supposed to have a 256K logic analyzer. How can I verify that it is really 256k?
    Would I just connect a known frequency square wave to one channel and see how long it samples? But how do I know how much memory is taken per transition?
  2. spinnaker
    Oct 29, 2009
    5,103
    1,192
    Or would I simply use my internal clock and see how long I can sample?
    This is what I get with 100KHZ clock
    Memory Sample Time
    2K 10.25ms
    16K 81.9ms
    32K 163.85ms
    64K 327.69ms
    128K 655.37ms
    256K 1.31s
  3. Brownout
    Jan 10, 2012
    2,375
    998
    The sample time should be memory_depth/(sampling_frequency*number_channels) Thus, for 100K samples/sec, you should get 262144/100K = 2.62S for single channel.
    That is, if the memory size is given in units of samples, which is usually the case.
  4. spinnaker
    Oct 29, 2009
    5,103
    1,192
    Look at my table above. Looks like I am getting about half of that.
  5. Brownout
    Jan 10, 2012
    2,375
    998
    Are you sampling only one channel? Maybe you inadvertently have a scond channel active???
  6. spinnaker
    Oct 29, 2009
    5,103
    1,192
    I see the issue. There is a setting called Page. By default it is set to 1. I have choices 1-15. If I set it to anything but 1 I get twice the sample period.
    I know Page has something to do with the trigger, but I have no idea what. The help file does not seem to explain it.
  7. spinnaker
    Oct 29, 2009
    5,103
    1,192
    Oh I am only measuring one channel too. But strange if I add a channel and I have page set to something other than one, I still get 2.61s for 128k. It almost seems like memory setting is per channel?
  8. Brownout
    Jan 10, 2012
    2,375
    998
    I've never seen this option on any LA I've used. Sorry, can't help there.
    That could very well be.
