Yes, I do. But I didn't learnt much about Fourier and nothing about Laplace.Do you have any calculus behind you?
If you're not willing to show me how I could do that, I can ask to my professor at university and see what he says.
We can work through it, but it will be a slow process. The material you are looking for is usually part of a Circuits II course.Yes, I do. But I didn't learnt much about Fourier and nothing about Laplace.
Hmm... I've never seen a Diffy-Q course that didn't include Laplace, usually as one of the last subjects in the course. But just because I've never seen it doesn't mean it's not the case.I've done all the calculus subjects, including differential equations. I don't know why I didn't see anything related to Laplace.
You use the formula MrAl gave you in post #7:To all: how do, then, I calculate voltage across a capacitor in an ac series circuit?.
I've found too complex the second link you gave me. So I went back to the previous page, the homogeneous solution, to refresh my mind about the DEs. Thanks a lot.Kiroma, it might be to your benefit to first study this:
http://www.mcvts.net/cms/lib07/NJ01911694/Centricity/Domain/134/1st order SystemsTransient Analysis.pdf
and this:
http://fourier.eng.hmc.edu/e84/lectures/ch3/node9.html
What is the page number?I've found too complex the second link you gave me. So I went back to the previous page, the homogeneous solution, to refresh my mind about the DEs. Thanks a lot.
But I think I've found an error in this page...
Specifically in the following sentence:
The time constantcan be identified on the time plot of the general first order responsewith.
=> this is not true.
What does it mean?
http://fourier.eng.hmc.edu/e84/lectures/ch3/node7.html at the bottom of the page.What is the page number?
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Aaron Carman
