verifying circuit
Discussion in 'The Projects Forum' started by studystudystudy, Jul 4, 2010.
  1. studystudystudy
    May 21, 2010
    34
    i try to build a energy harvesting circuit from some material capable to generated electric when applied mechanical force such as piezo.
    despite all value in the circuit.
    can my circuit work with this schematic design?
    1. V1 is the input source **(ignored the value of V1)
    2. the two zener diode D1 and D2 used to limiting the voltage. (back to back zener diode concept)
    3. general diode D3,D4,D5,D6 act as rectifier.
    4. c1 is used to stored the amount of energy
    5. D7 and D8 is used to voltage regulator
    6. c3 is used to stored the energy
    please refer and see the attachment below
    thank you very much, your helps will deeply appreciated
  2. retched
    Dec 5, 2009
    5,201
    313
    studystudystudy likes this.
