velocity control
Discussion in 'General Electronics Chat' started by electronics1, Feb 10, 2010.
  1. electronics1
    Thread Starter Active Member
    Aug 21, 2009
    42
    I want to do that if I push a button then the robot has a maximum velocity that is less than the maximum velocity without to push the button
    How I can do this?
    What kind of methods exists to control velocity?
    Can I do it with gyroscope or encoder sensors ?
    If the answer is yes than
    1. I search after information that explain about the gyroscope sensor
    2. how can i do this whit encoder sensor ?
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  3. mik3
    Feb 4, 2008
    4,846
    63
    Do you have a mean for measuring or estimating the robot velocity?
  4. electronics1
    Aug 21, 2009
    42
    I want to vary the velocity
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Then use PWM to drive the motors if they are DC.
    If they are stepper motors, change the step rate.
    If they are AC motors, you will have to vary the frequency of the drive.
