Velocity and Acceleration
Discussion in 'Homework Help' started by Breeze, Sep 20, 2015.
  1. Breeze
    Jun 30, 2015
    24
    Morning to you fellow Engineers,i need help with this Assignment question on velocity-"A particle is moving along the x-axis so that its distance,x in meters,at time,
    t in seconds,is x(t)=3,2 √ tan 5t. Find its velocity at time t=1,5 seconds .i know velocity is "dx/dt"in this case but i have a litlle problem with solving going forward.Any assistance in this question will be greatly appreciated.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    So step 1 is to compute the derivative. How should you go about setting that up?
    You might also want to learn Tex, which this site supports. Is this your position function?
    x(t)=3.2 sqrt{tan(5t)}
  3. dannyf
    Sep 13, 2015
    2,196
    417
    dx(t) / dt = 3,2 d(sqrt(tan(5))) / dt = 3.2 * 1/2 * [tan(5t)^-0.5] * d(tan(5t)) / dt
    after that, you can either use a formula on d(tan(5t))/dt, or think of tan(5t) as sin(5t)/cos(5t) and go from there.
  4. Breeze
    Jun 30, 2015
    24
    yes it is
  5. Breeze
    Jun 30, 2015
    24
    thanks a lot Papa bravo
  6. Breeze
    Jun 30, 2015
    24
    Many thanks this is absolutely helpful indeed.
  7. WBahn
    Mar 31, 2012
    18,085
    4,917
    Yes, isn't it always helpful when someone does your homework for you?
    panic mode likes this.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    @dannyf ...At least you didn't give him the final result.
    @Breeze ...Are you going to show us the final finished result? In TeX?
  9. Breeze
    Jun 30, 2015
    24
    i am not yet proficient with TEX but will soon study it,i have actually came across it in a couple of other sites as well..
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    It's well worth getting familiar with. It is far, far more then just something for making formulas display in a forum -- it is intended for electronic typesetting in general. For instance, my entire PhD dissertation was written in LaTeX, many (most?) professional journals and conferences want submissions to be in TeX/LaTeX, and many book publishers require that it be used.
  11. Breeze
    Jun 30, 2015
    24
    Thanks a lot Sir,your advice is absolutely invaluable,may i know which site i can get comprehensive info about LaTex so i can start learning it?
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
  13. Breeze
    Jun 30, 2015
    24
    Thanks a million
  14. Russmax
    Member
    Sep 3, 2015
    81
    12
    Thanks for the pointers on TeX. I joined the forums about a month ago, and I did not know you could do this. I've been typing ugly text formulas.
