velleman signal generator
Discussion in 'The Projects Forum' started by ninjaman, Mar 26, 2014.
  1. ninjaman
    May 18, 2013
    306
    hello
    I have a velleman signal generator kit that I have put together and it works fine but only gives 100mv pk-pk.
    is there any way I could adjust it to give 1v pk -pk?
    im thinking its just changing a few resistors though my circuit analysis isn't very good and im not to sure what to change. its a basic 555 circuit that gives sine, saw, square and another(cant remember the name)
    I will try to attach a schematic I found on google
    any help or advice would be great
    thanks
    simon View attachment manual_mk105.pdf
  2. MrChips
    Oct 2, 2009
    12,625
    3,451
    Increasing the signal from 100mV to 1V requires an amplifier with a gain of 10.
    You cannot achieve this by simply changing resistors in the circuit.
  3. ninjaman
    May 18, 2013
    306
    if I put an amplifier after it, that would increase it but would it do anything to the waveforms?
  4. Dodgydave
    Jun 22, 2012
    5,150
    769
    use an op amp like this, the wave forms will only alter at the high kilohertz.
  5. t06afre
    May 11, 2009
    5,939
    1,222
  6. GRNDPNDR
    Member
    Mar 1, 2012
    449
    7
    Won't this need a negative power supply for the op amp if he wants to maintain he signal properly?
    In which case he would need two batteries or a rail splitter circuit.
