The link I posted earlier is a good bet. Saves shipping from the US.If I'm purchasing in the UK should I click the link given earlier that leads to Microchip Express or does Microchip have a distributor in the UK?
my link was bad. Here is the one I meant to linkWhat is the in debug kit that isnt in the basic kit and can the extra's be purchased later?
Are they really that expensive? I pay less than a dollar for a TQFP44 adapter.my link was bad. Here is the one I meant to link
The main difference is that kit uses PIC16 DIP ICs rather than a PIC18 44 pin Surface Mount. You can purchase a 3 pack of the 44 pin QFP for $50US
The debugging and examples differ slightly, the 44 pin has one button, one potentiometer, and 8 LEDs. The starter kit has 1 potentiometer, 1 button, and 4 LEDs.
Both have all I/O of the processor brought out to pads and a through hole prototyping area.
So, there's not really much difference. You wouldn't want to use up more pins on the DIP PIC anyway, as you'd have fewer available for other projects that didn't involve lighting LEDs.
My bad. $25 for 3 1 populated and 2 blanks. You can get the other chips free as samples to populate the other two.Are they really that expensive? I pay less than a dollar for a TQFP44 adapter.
The Vellemann board is not so good. I used it years ago. It only supports some older PICs.
The PICKIT2 is outdated as well.
Use a PICKIT3.
No you will not miss anything. The debugger version has a slightly more advanced chip than the low pin count version. But both has the same standard PICKIT2 unit. One thing Then you get the package. Do not install MPLAB from the CD. This is probably an older version of MPLAB. Get the newest version from the microchip web pageOh and by ordering the debugger version have I missed out on anything that comes with the starter version?
I used to use one of these:I'd probably prefer to use the officially recommended adapter for now and get a bit more experimental later when I understand things better.
I am using MPLABv8.88 at home and uni
Hey this was my first programmer module too.I used to use one of these:
http://www.maplin.co.uk/high-power-multi-voltage-desktop-power-supply-48517
It burnt out after a couple of years of light use.
You must use a regulated 15V supply, not one of the cheaper unregulated supplies.
Don't waste another £20 to £30 on a PSU for that rubbishy old Velleman monstrosity; you have wasted enough money already.
Get a genuine PICkit2 or PICkit3.
... and as a bonus, PICkit2 will program and supply power for your Velleman board without the need for an expensive 15V regulated adapter. I assume that PICkit3 will work with it too, but I do not own one to try it out.
Do you know of free software for programming GALs? I somehow ended up with about 100 of them, I have an EPROM Burner (Universal programmer that supports GAL through PIC), just no way to make the file the .GAL needs. I went from microcontrollers to FPGA, skipping over GAL and CPLD.I have ended up with two GAL programmers, one can not be used with my current Windows so it's sitting there and gathering dust. Same for one old Motorola controller demo board- hopeless outdated IDE software which does not work as well anymore.=
