Velleman MK103 Sound to light project
Discussion in 'The Projects Forum' started by JayroK, Feb 2, 2012.
  1. JayroK
    Feb 2, 2012
    Hello all,
    I m about to start a DIY project with the MK103 sound to light unit and i had some questions
    I am fairly new to electronic DIY but i want to use the MK103 with over 80 leds at the same time.
    basically instead of having 4 led light up with the sound i want over 80 to do so.
    How should i proceed?
    any help would be appreciated, as i say i am new to this type of DIY.
  2. KJ6EAD
    Apr 30, 2011
    1,426
    364
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Replace the LEDs with an N-channel Mosfet. Connect a 1k resistor to ground from the gate of the Mosfet to turn it off. The Mosfet can drive many LEDs connected in strings. Each string will have a few LEDs in series and in series with a current-limiting resistor.
    The strings of LEDs will need a power supply to provide enough current.
