Velleman MK-103 for strobe light
Discussion in 'The Projects Forum' started by ronc, Oct 8, 2011.
  1. ronc
    Oct 8, 2011
    Hello, I was hoping someone can help me with this.. I just bought a MK-103 tonight to run a flash (strobe light) for my camera.. any reason why this should not work? What I want it to do is pop the flash off. I don't need all 4 LED's but one would be nice for testing.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Greetings! And welcome to AAC!
    Your post, originally found here (http://forum.allaboutcircuits.com/showthread.php?t=58252), has been moved into its own thread, where it will draw more responses.
    Please refrain from "hijacking" existing threads with tangent or off-topic questions. You can create new threads for new questions using the "New Thread" button on the upper left of the page.
  3. ronc
    Oct 8, 2011
    Ok thanks!
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's been awhile since I've had a flash attachment, but if I remember correctly, shorting the terminals together causes the unit to flash. Is that the case with yours?
    What voltage do you measure across the flash terminals when it's ready to flash, but not shorted?
  5. ronc
    Oct 8, 2011
    I didn't check the voltage yet. I have about 6 flash's and 4 studio lights so I'm hoping to find something under 10v. And yes, when you short the contacts the flash will pop. if I need to I can also run this wireless and that would be <1v to trigger.
  6. KJ6EAD
    Apr 30, 2011
    1,426
    363
    I'm not sure how the sound to light kit came into this. Are you trying to make a sound activated flash trigger?
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    KJ6EAD,
    That's what I'm understanding that they want to do, along with retaining 1 LED to flash as a debugging aid.
    R9 will need to be increased in value to around 560 Ohms.
    It might be as easy as connecting T4's emitter/collector junction across the flash terminals, but we don't know if there is a voltage there at the moment.
    It would be safer to use a separate transistor with a base resistor.
  8. ronc
    Oct 8, 2011
    Yup, That would be it.. I want to do a few hi speed shots. Most of what I'm doing will make some kind of sound so I figured this may be a good option..
    I'm thinking I will probably go wireless. I only have one transmitter now but they are kinda cheap and have a test button I can work off of. I'm guessing the trigger voltage would be in the <500mv range but my battery is dead so I can't test the 23a.. the triggers are PT-04's
    http://dptnt.com/2010/05/diy-radiopopper-px/
