Vector proof
Discussion in 'Homework Help' started by JasonL, Oct 5, 2013.
  1. JasonL
    Thread Starter Active Member
    Jul 1, 2011
    47
    Problem: Let A be an arbitrary vector, and let e be a unit vector in some fixed direction. Show that, A=e(A\bullete) + e x (Axe)
    Work:
    A=e(A\bullete)+ex(Axe)
    A=|A|cos(θ)e + e x (|A|sin(θ)n)
    A=|A|cos(θ)e + Asin(θ)sin(90°)
    This is as far as I got. I'm not sure if I'm going in the right direction.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Aren't the two angles the same?
    How did the vector A pop back into your second term in your third line?
    You might try writing things in terms of vector components and not even introduce trig functions at all.
    JasonL likes this.
  3. JasonL
    Jul 1, 2011
    47
    You're right the angles are the same. I realized that vector e x |A|sin(θ)n wouldn't give me A but a vector perpendicular to n. I didn't think about solving it in vector components, but trying to solve it with undefined variables made the work messy really quick. I chose arbitrary values that fit that problem and it worked. Thanks!
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    So now go back and use generic vectors:
     \vec A \, = \, A_x \hat x \, + \, A_y \hat y \, + \, A_z \hat z
     \vec e \, = \, e_x \hat x \, + \, e_y \hat y \, + \, e_z \hat z
     e_x^2 \, + \, e_y^2 \, + \, e_z^2 \, = \, 1
