-ve voltage generation 555
Discussion in 'General Electronics Chat' started by aamirali, Mar 7, 2012.
  1. aamirali
    Feb 2, 2012
    415
    I have checked -ve voltage generator by 555, here
    http://www.eleccircuit.com/12vdc-negative-voltage-dc-converter-by-555/
    But I don't understand why cap C4 whose +ve side is positively charged & -ve plate is grounded during positive cycle.
    Then why during 0V cycle, +ve plate is at zero & -ve side is at -vcc potential.
    Do charge gets transferred
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. buzaiandras
    Member
    Jul 18, 2011
    54
    If I understand it correctly (I might be wrong, I am a beginner) during the 0V cycle the +ve plate is brought to 0V potential by the 555 timer. But the +ve plate is still at a higher potential than the -ve plate. the capacitor is still charged. You can think of it as a change of reference for the voltage measurement.
    So if -ve is at a lower potential than +ve then when +ve is brought to 0V it means that -ve must be below 0. This is why it is at -vcc.
    Something similar happens with the capacitors in a astable multivibrator.
    Maybe somebody with more experience can shed light on this for us :)
    Thank you
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes you are right
    http://forum.allaboutcircuits.com/showpost.php?p=200183&postcount=12
