VCO in kHz range
Discussion in 'General Electronics Chat' started by JWBates, Feb 3, 2016.
  1. JWBates
    Jan 27, 2016
    Hi all,
    I am trying to find / buy a voltage controlled oscillator in the kHz range. Ideally I need it to be between 40 kHz - 70 kHz output as a sine wave.
    I have spent hours trawling online but everything seems to be MHz GHz.
    Can anyone point me in the direction of a supplier who sells this kind of chip.
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    Welcome to AAC!
    Many opamp application notes will have a VCO (square wave) example. Adding two integrators will give you a sine wave.
  3. hp1729
    Nov 23, 2015
    2,097
    232
    ICL8038. Creates a sine wave up to about 300 KHz. The pot adjustment can be changed to a voltage input I suppose. Exar makes a similar device. XR2206 I think it was.
  4. JWBates
    Jan 27, 2016
    Thanks, hp1729 that's a big help.
