Vcc stuck high problem
Discussion in 'General Electronics Chat' started by cuden, Nov 18, 2009.
  1. cuden
    Nov 18, 2009
    There is a leakage cap in the circuit, when I turned off the power switch then vcc slowly dropped down and not all the way to zero voltage on the scope compare to the good one it's promtly dropped to zero. I need help, is there any ideas out there? BTW, I tried to removed all the caps related to the Vcc, but still having the same problem??? :confused:
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What circuit are you talking about?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It would help a great deal if you posted a schematic of the circuit.
    .png format is preferred. .jpg files are too "lossy" to be of much use.
    .pdf files are also acceptable.
    Use the "Go Advanced" button, then the "Manage Attachments" on the following screen to navigate to/attach/upload your image file(s).
