VCA - does this work?
MachineHum
Joined Nov 3, 2014
74
Source: http://www.next.gr/audio/amplifiers/voltage-controlled-variable-gain-amplifier-ii-l12486.html
Hey guys/gals, I found a schematic for a VCA (Voltage controlled amp) online. It uses a FET to very the gain with V- (Gain control pin) This could be a simple solution for what I'm looking for. I wrote in some of my math off to the right, I'm not sure if it's actually doing what I says it's doing. It seems to me more like an offset then anything, my cct analysis is a little rusty so if anyone want's to chime in that would be cool :)
"k" would be a constant of the FET, I mostly ignored polarities as I'm concerned with magnitudes.
ian field
Joined Oct 27, 2012
6,536
Its an NS appnote that's been floating about for donkey's years - I assume it works as described, but never actually tried it.
The old favourite was the CA3080, but that's long since unobtaneum - I believe the current favourites are the LM13700/13600 types.
One I've had some success with in a 8-DIL package is the A suffix variant of the TDA7052 BTL amplifier which has DC controlled volume control.
Its designed for full bridge drive of a low impedance speaker, but you can use one of the outputs single ended at reduced power - still plenty for small signal use.
