Vc vs Vin of NPN
Discussion in 'Homework Help' started by TsAmE, Oct 4, 2010.
  1. TsAmE
    Apr 19, 2010
    72
    Calculate the collector voltage Vc as Vin increases from 0-5V and hence plot the transfer characteristic Vc vs Vin (consider many points where Vc is changing rapidly). Calculate Vin when Vc = 2V. An NPN with a gain of B = 100 is used.
    Attempt:
    When Vin = 0V and 1V Vc = 0.
    Vin = 2V: Ib = 2 - 0.7 / 10 x 10^3
    = 1.3 x 10^-4
    Ic = IbB
    = 1.3 x 10^-4 x 1000
    = 0.013
    Vc = 5 - 0.013 x 1 x 10^3
    = -8V
    I dont understand why I got a negative answer.
      File size:
      43.4 KB
      23
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    In principle once you have enough base current to drive the collector voltage to 0V (actually it would be to Vce_sat) it can't be driven less than 0V - a condition called "saturation".
    So for Vc to be zero then Ic would be 5mA. To just drive Ic to 5mA would require Ib=5mA/β=50uA.
    To get Ib=50uA with Vbe assumed as 0.7V would require
    Vin=10k*50uA+0.7=1.2V
    An input voltage greater than this would lead to the saturation condition.
    This isn't exactly what will happen in practice - but will suffice for the sake of this simple problem statement.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    You are getting a negative answer because you have calculated a collector current that is greater than is possible to pass through the 1K resistor with the given voltage (5mA).
  4. TsAmE
    Apr 19, 2010
    72
    Howcome Vin = 1.2V would lead to saturation? Since the rule that the transistor will turn on if Vin - 0.7 >= 0.7V isnt fufilled? (with 1.2 - 0.7 = 0.5V)
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    To open small signal BJT you need Vbe grater then 0.5V.
    Your circuit will be in saturation if Ib is grater then Ib > ( Vcc / β*Rc ) = 5V/100KΩ = 50μA
    This base current will cause voltage drop on RB resistor equal to :
    Vb = Ib * RB = 0.5V
    So for Vin grater then Vin > ( Vcc*Rb / β*Rc ) + Vbe BJT will be in saturation.
    Of course we assume that β is constant, witch is not true .
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    Saturation isn't a state before the transistor turn-on (or active region as it is called). It is actually achieved if you turn on your transistor "too-much".
    In increasing order of ib (and Vbe consequently) the transistor goes from cut-off, to active, to saturation. In the last state it cannot increase any more the current of the collector and therefore the relation Ic=β*Ib isn't valid anymore.
