VB6 Replacement
Discussion in 'Programmer's Corner' started by RamaD, Feb 7, 2014.
  1. RamaD
    Thread Starter Active Member
    Dec 4, 2009
    254
    33
    I have been using VB6 with MSCOMM control for communicating with microcontroller from PC, for sending commands to uC and collecting data from uC, using RS232 serial interface.
    VB6 is not supported by Win 7, though the compiled code works, there is a need for a replacement to VB6 for new programs. as XP goes obsolete. Please correct me if I am wrong!
    Can someone please suggest an alternate for VB6, which would require minimum learning!
  2. sirch2
    Jan 21, 2013
    1,008
    351
    RamaD and strantor like this.
  3. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Yep. Visual Studio (which contains Visual Basic dot net) still has a COMM control or something that works like it; I'm not sure if you drop a control on a form or just reference it but it's there, it's free to try, and will be in the help files.
    RamaD likes this.
  4. atferrari
    Jan 6, 2004
    2,663
    784
  5. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    I'm using VB6 on windows 8... The OPsys complains like hell... But it works... I cannot get the MSDN libraries on though!!! Help has changed toooooo much. But as I have a net connection I can still get help!
    Forgot to ask.... What do you need VB6 for!!! If you try and learn C# it won't go out of fashion....
    I use Blitzbasic ( the old amiga in me )
    There is just Basic ( old liberty basic)
    There is BBC basic for windows... Uses the old archimedes syntax...
    Loads......
    RamaD likes this.
  6. sirch2
    Jan 21, 2013
    1,008
    351
    Java and Python come immediately to mind. Windows Scripting Host can most likely do it. Various versions of C e.g. GCC/MinGW; FreeBASIC; GNAT ADA
    Google has many more. The up-shot is that most of these things don't actually need "installing" the are just a collection of Executables and DLLs and as long as they can be found on the Path then they work on many versions of Windows. The limitation WRT to the OP's question is do they have the native libraries, or access to COM objects, for accessing the serial port. AFAIK those I have listed do.
    RamaD likes this.
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Depends on the Win7 version perhaps. the starter version can't use graphics mode but it will run stone age MSDOS compilers in text mode.
    Vista runs stone age Borland and Microsoft compilers altough the very first one's are junl because there is no way to display the help files.
    You could run older Windows from an external hard drive (IDE with USB/IDE adapter works actually if the BIOS supports USB boot).
    VB6 is kinda deprecated, and latest VS is very slow to startup on smaller machines. Solution: go for the VS2008, it is still modern but much faster to startup. The VB2008 is good for purposes such as RS232, there is functionality to use serial ports.
    Try to get a full version since it includes MSDN documentation.
    honestly the way Windows VS developement has changed has evoluted into a mess- the way the SDKs are used has changed quite a few times and there are quite a few concurrent technologies now in different versions. The Way of documentation has changed and evoluted as well.
    Keeping up using old VB6 and the like is fine but the user base becomes smaller and smaller.
    You can probably run it on a cheap laptop or netbook with Vista (but that's kinda deprectated too). By the way, Win Server 2008 is technically kind of a Vista flavour. Was released together with VS2008.
    I have done a really ugly hack recently.
    I am ashamed of that and the fact it has come that far with Windows.
    From using LINUX for a while I became used to patching and hacking to make things work.
    OK. I got the new shiny netbook brand new with Win7 Starter. Turns out, 32bit OS + kinda 4-core 64bit CPU.
    OK. Installed VS2008 + MSDN + some SDKs- took me half a day.
    Then I try to compile- it is impossible, no 32bit compiler.
    I had the VS Express installed VS2013 but never used- slooooow.
    I then had the genius stroke idea to point the VS2008 to the VS2013 linker (just that). Kaboom. My stuff compiled fine + it can execute totally perfectly.
    Some SDKs (but not the brand new Metro stuff AFAIK) also contain VS binaries (aka compilers, linkers).
    Believe me, if you don't always keep up buying the latest release full version + matched powerful machines, using dev. tools with Windows (of random flavour) is a mess.
    Just for fun I downloaded nearly all old versions of C++ tried to make them compile the supplied examples.
    I have the original old DirectX SDKs on my blog for download- from 1 almost nothing works anymore, but from 2 some work, and from 3, a surprising large amount of precompiled binaries work.
    RamaD likes this.
  8. RamaD
    Dec 4, 2009
    254
    33
    Wow! So many recommendations! I am studying the alternatives and trying to zero in on some best fit for me.
    @sirch2:
    I am trying to use data controls which gets the job done with literally no programming work (me lazy). I am looking at your alternatives too.
    @Ian Rogers:
    How did you manage to install VB6 on Win 8? I dont have Win 8 PC yet. On Win 7, VB6 installation would not go through. With some help from the net, I could proceed a bit further, but could not complete installation.
  9. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    I did struggle.... But it did go on.. I had to disable a couple of things in the boot sequence ( there is a guide online )... But at least its working...
    RamaD likes this.
  10. ScottWang
    Aug 23, 2012
    4,926
    777
    RamaD likes this.
  11. ActivePower
    Member
    Mar 15, 2012
    155
    23
    Python sounds good for your requirements. It has a minimal learning curve, works across platforms and has easy access to the serial/USB ports through many freely available libraries.
    Here is a minimum working example to talk to your COM port:
    Code ( (Unknown Language)):
    1.
    2. # Sample application to try pyserial library (Python 2.7)
    3.
    4. # Get the pyserial library
    5. import serial
    6.
    7. def Comm():
    8.
    9.     serial.com = serial.Serial(2, 9600)          # Open COM3 at 9600 baud
    10.
    11.     print serial.com.portstr                      # Print port name
    12.
    13.     line = serial.com.read()
    14.     print line
    15.
    16.     serial.com.close()
    17.
    18. def main():
    19.
    20.     Comm()
    21.
    22. # Boilerplate code (you could probably skip this for smaller projects)
    23. if __name__ == '__main__':
    24.     main()
    25.
    Hope this helps.
    RamaD likes this.
  12. RamaD
    Dec 4, 2009
    254
    33
    @takao21203:
    You are really resourceful and adventurous! Special Thanks for all the tips.
  13. josip
    Member
    Mar 6, 2014
    63
    12
  14. VB6 programming
    Feb 11, 2015
    6
  15. tshuck
    Oct 18, 2012
    3,531
    675
  16. VB6 programming
    Feb 11, 2015
    6
    They are, though for most of us support is limited to the VB6 Runtime (that is apps you develop). The IDE isn't supported unless you pay for a custom support agreement. However they do make 'every effort' to ensure the VB6 IDE runs on newer releases of Windows, and it does run fine on Windows 7, 8.1 and the Windows 10 technical preview.
  17. tshuck
    Oct 18, 2012
    3,531
    675
    They explicitly state in the link that there is no support or updates for the IDE.
    The runtime is supported for 5 years after the OS ships, which, for Windows 7 is now, then goes into Extended Support.
    No VB6 has, or will have, 64-bit OS support.
    While VB6 is basically on life support, it's probably better to just move on and let it die quietly.
    But, the thread is referencing XP, which has no support.
  18. JWHassler
    Member
    Sep 25, 2013
    204
    34
  19. VB6 programming
    Feb 11, 2015
    6
    Custom support is available for the IDE, but has to be paid for.
    The VB6 IDE and the VB6 Runtime both run on 64 bit PCs. The runtime is supported whether on 32 bit or 64 bit.
    VB6 isn't supported on operating systems that are no longer supported. So Windows 7 support ends in 2020. The support policy under Windows 10 is unlikely to be announced until Windows 10 is launched.
  20. tshuck
    Oct 18, 2012
    3,531
    675
    ...And? Having support available and being actively supported are two different things.
    From the link I already posted (emphasis mine):
    Read the support lifetime statements - Mainstream Support ends this year for Windows 7, and enters into Extended Support (which is not the same) for the next 5 years.
