Hi Guys,
I am making a code in VB6 that will combine the 2 PDF Files. This is the code that I just copied in the internet:
Private Sub Command1_Click()
Me.MousePointer = 11
Dim origPdfDoc As Acrobat.CAcroPDDoc
Dim newPdfDoc As Acrobat.CAcroPDDoc
Dim path As String
Dim path2 As String
Dim varNewTotalPages As Long
path = "C:\Users\joem\Desktop\Databook\New Folder\3.pdf"
path2 = "C:\Users\joem\Desktop\Databook\New Folder\4.pdf"
Set origPdfDoc = CreateObject("AcroExch.PDDoc")
Set newPdfDoc = CreateObject("AcroExch.PDDoc")
If origPdfDoc.Open(path) Then
If newPdfDoc.Open(path2) Then
'Get total # of pages too insert
varNewTotalPages = newPdfDoc.GetNumPages
'Insert pages into original pdf
origPdfDoc.InsertPages True, newPdfDoc, 0, varNewTotalPages, False
'Save doc
origPdfDoc.Save PDSaveIncremental, path
Else
MsgBox "Failed to open doc " & path2
End If
'Close docs
origPdfDoc.Close
newPdfDoc.Close
MsgBox "Pages added to " & path
Else
MsgBox "Failed to add pages to " & path
End If
Set origPdfDoc = Nothing
Set newPdfDoc = Nothing
Me.MousePointer = 0
End Sub
I already check the "Adobe Acrobat 9.0 Type Library" but every time I run the program I am always getting this error "ActiveX component can't create object"...Can anybody help me how to solve this?....See attached file for the actual error
Dim path As String
Dim path2 As String
'Save doc
Else
End If
'Close docs
origPdfDoc.Close
newPdfDoc.Close
Else
End If
Me.MousePointer = 0
End Sub
