VB vs XBASIC
Discussion in 'Programmer's Corner' started by Wendy, Jun 23, 2008.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    OK, in another thread it was mentioned than VB is not much fun to use, and recommended XBASIC. I'd be interested, GUI is not important, but the ability to use modern visual and sound formats is, such as JPG and PNG files, or .WAV (just examples, get me to a modern standard, and it can be converted).
    It also needs the ability to communicate with memory directly, as in printer ports.
    Any thoughts?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I was kinda negative about VB because the emphasis is on designing the GUI screen - so much so that the purpose of the program got lost. That may just be my style - I find writing the code to perform the function to be much more interesting than the user screen. And, if you just want do do some control functions, the GUI isn't very helpful.
    Having access to the computer at the hardware level is pretty simple with about any of the various flavors of Basic. Some, like Xbasic are freeware. Some, like Power Basic, cost money, but have lots of functionality with Windows systems built in.
    Google around and you'll find several kinds of Basic available. Nobody ever made an editor to compare with the one in Qbasic, though.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Ah, QBASIC, I still program in both GW and Q. The lack of proper interfaces is a killer for these older languages, if they had upgrades I would be quite happy with them.
    But then, I still have a C128 with a 4 Gig hard disk set up and working.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Did you ever run down QBX? That id Qbasic with some extensions and the ability to compile code beyond 64K. I've got it, but was just able to run doen some manuals only recently. It's probably too dated to work well, though.
    I'd probably fool with the old Apple IIe, but the keyboard died. I had the only clone IIe that made it here before Apple shut that door. Your Commodore sounds pretty good - IIe's never had much for hard drives.
  5. RiJoRI
    Aug 15, 2007
    536
    26
    I'm a bit of a collector of (free!) programming languages. My BASIC list is:
    BASICA
    BASm
    BasPas
    BasicBASIC
    CB
    Chipmunk
    FirstBasic
    FreeBASIC-DOS
    FreeBASIC-Win
    GCBASIC
    HLA
    Liberty BASIC
    MBC
    MicroBasic
    MoonRock
    OBASIC
    QBC
    SIC
    Script
    Small BASIC
    TSR
    WS BASIC
    WX BASIC
    X11 BASIC
    XBASIC
    bwBASIC
    I find Liberty BASIC to be most useful to me -- in fact, I even PAID for it! :eek:
    --Rich
  6. atferrari
    Jan 6, 2004
    2,663
    784
    Turbo Basic any time? I became quite proficient with it.
    I've even got paid for some good soft writen with it! It was the whole trim calculation for a freighter vessel including stability calculations with bells and whistles.
    Later I did the same for a tanker vessel.
    The last I did was adding mouse capability calling DOS functions. For reference I used a book stating every single docummented / or not function in DOS.
    O God, I enjoyed doing that!
  7. nigelwright7557
    May 10, 2008
    488
    71
    BASIC is not the best lnguage to write programs in.
    Download Microsofts Visual C# express as its free and very powerful.
    If yo ureally have to use BASIC then downlaod Microsofts Visual BASIC express.
  8. atferrari
    Jan 6, 2004
    2,663
    784
    Visual BASIC and the "old" BASIC have, I should say, almost nothing in common. Just the name.
    Is rather misleading to compare them when they are actually different languages not varieties of the same thing.
    Suffice to read any piece of code written in VB and that would be evident.
    The fact that they use SOME, and very few, similar reserved words doesn't make similar languages of them.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Actually, in my limited experience with VB you can follow all the old BASIC conventions and it will work, which makes it a true BASIC. They just followed the path HP set for its BASIC to its logical conclusions. Having said this, I don't know VB, but have relied on some experiments with a friend. The question came up whether it could use line numbers (which is an obsolete concept with anything modern), and it did.
    Thier is nothing wrong with BASIC as a language, and it is easier to learn a new dialect than a new language.
