Maybe I was misunderstood when I said;I will leave that for some one else that knows the difference.
You would not take my answer serious until you use the wrong type
oil and get a big surprise,If no one else knows ,more surprises.
It's not that I've used a jug of vaseline in a single go, but rather that I've worked with a lot of hydraulics. If I had to guess, I'd say a hundred jars of vaseline against several million gals of hydraulic fluid. Just a guess mind you, over 30 years of Millwrighting.I've gone through plenty of Vaseline when working with hydraulics. Excellent for O rings.
I've used it for this and it works, but I like axle grease better because things tend to stick better.Its stickyness often makes parts stay in place long enough to get them assembled.
I seem to recall the all-in-one, came in a green and white rectangular can.@GetDeviceInfo,before you sign off.I am making a post. I designed a hydraulic car trailer.
I paid for the welding,so i have some experience working around hydraulic,But the
oil experience happened when I was oiling something that went wrong,you have heard
of all in one oil,some simple name like that,the point I was holding out on was when
I oiled a hilti gun with regular oil,the next time it fired it froze up,so that where using
the right oil for the job comes in.Its been a fun subject. Please reply.
don't strain yourself.I told you It was coming I should have held back for real oil talk
Interesting -- I assume you mean the usual silicone grease like that used in Dow Corning vacuum grease or lab grease for stopcocks? That sounds like a good idea -- thanks for the tip! I use plumber's waterproof silicone grease for all the o-rings around the house and occasionally as a thread lubricant on stainless steel (having worked in the ultra-high vacuum industry, I've seen how horribly stainless can gall to stainless and even aluminum).@someonesdad
New discovery...silicon spark plug grease. Thicker than Vaseline which melts and disappears in the Florida heat. Try that on your striker plates. It lasts longer.
Thread starter | Similar threads | Forum | Replies | Date |
Silicone that does not cure, vaseline, some self-healing gel... | Off-Topic | 3 |
Similar threads |
by Jake Hertz
by Duane Benson
by Aaron Carman
by Jake Hertz
