Vaseline
Discussion in 'Off-Topic' started by someonesdad, Jul 18, 2011.
  1. someonesdad
    Thread Starter Senior Member
    Jul 7, 2009
    1,585
    141
    Vaseline is one of my favorite things in the shop. I keep a syringe with Vaseline in it with a large gauge needle with the tip ground blunt. Use it to inject some Vaseline where you need it (set it in the sun for a while to soften things up). I use it on fastener threads and when tapping. It's dynamite for kitchen drawer rollers -- and lasts for years. It's just the thing for door hinges -- lasts a lot longer than mineral oil based oils that gum up after a while.
    Smear it on where you don't want paint, epoxy, or solder to stick.
    Every woman in the world knows to put Vaseline on the bottle threads of nail polish to keep things from sticking. This works great in the shop too -- I think my favorite use is on the threads of those cans of PVC cement that seem to be designed to dry out and stick. Use it to stop sticking and put enough on to make a good seal. I've got a can of cement I've opened and sealed many times over the past couple of years.
    When you're done with a tube of caulking, silicone sealant, etc., suck the material back into the tube a ways then put a dab of Vaseline on your finger and plug up the hole or the caulk tip. When you need to use that tube a year from now, just squeeze out the Vaseline onto a paper towel and you're back where you started. I wish I had thought of this decades ago so I didn't have to throw out so many dried tubes...
    By the way, to get the Vaseline into the syringe, pack it in with a Popsicle stick. Then heat it in the steam from a teapot to melt it -- this lets you squeeze out the excess air.
  2. TBayBoy
    Member
    May 25, 2011
    148
    19
    I wouldn't put in on pressure vessel threads like oxygen tanks. u go boom :(
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I've gone through plenty of Vaseline when working with hydraulics. Excellent for O rings.
  4. loosewire
    Apr 25, 2008
    1,584
    435
    Viscosity will bite you sooner or later,remember that.It for real not a secret.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    I've suspected lip balm is modified vasoline. I use lip balm when my nose starts getting cracked up. I use a Q-Tip to apply it inside my nose, where it does for it what it does for my lips. Betcha Vasoline would work too.
  6. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    and what should one watch out for?
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Napalm - Jellied Gasoline
    Vaseline - Jellied Petroleum
    Hmmm?
  8. Markd77
    Sep 7, 2009
    2,803
    594
    Just had a look at Wikipedia, it's probably best not to stick it up your nose:
    I used to use it on the threads of the lids of beer pressure barrels which seemed to help get a better seal.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    So did they mention lip balm? I'd always assumed they were the same thing.
    When I was very young and had trouble breathing my mom would rub some under my nose and on my chest. I believe the label says this use I OK. It would free up my breathing a lot.
    Like lip balm, putting a thin layer will put an end to cracking and bleeding inside the nose, along with the painful scabs caused by it. I'll live with the risk, it is not like it is needed constantly.
    http://en.wikipedia.org/wiki/Vaseline
  10. gerty
    Aug 30, 2007
    1,154
    304
    Sure that wasn't Vicks Vapo-rub?
  11. Georacer
    Nov 25, 2009
    5,151
    1,266
    Yay! Vicks ftw! I used to use that too when I was like 5 or 8 years old.
  12. shortbus
    Sep 30, 2009
    4,092
    1,673
    Now they claim not to even use that in nose. Shoulda told my Mom.
  13. someonesdad
    Jul 7, 2009
    1,585
    141
    Be careful -- find out the type of rubber, as Vaseline will attack some rubber o-rings. Viton and Buna-n are probably OK though.
    TBayBoy's warning is a good one, although I would expect most adults already probably know it. Pressurized oxygen and greases/oils are a definite no-no because of the risk of spontaneous combustion or an explosion (which is just a fast form of combustion). However, you younger folks reading this board may not know it, so file it away for future reference.
  14. loosewire
    Apr 25, 2008
    1,584
    435
    I will leave that for some one else that knows the difference.
    You would not take my answer serious until you use the wrong type
    oil and get a big surprise,If no one else knows ,more surprises.
  15. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Ok, one suggested seal incompatibility. I've used it with Viton/BunaN/Silicone, typical industrial applications. Another suggests oil incompatibility. I've it with petroleum based, synthetic esters, and water based glycols.
    If either of you have a known incompatibility, it would sure help to mention it to avoid potential problems.
  16. someonesdad
    Jul 7, 2009
    1,585
    141
    I've used it with cheap o-rings in water-based systems and have seen the o-rings degrade. I don't know what type of rubber these o-rings were, as I didn't buy them. For such information, it's good to check o-ring manufacturer's information (e.g., Parker), as IIRC, I've seen chemical compatibility information there (this was 20-40 years ago when I was designing stuff, so it might all be dumbed down now).
  17. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Well I'll admit that my experience is with industrial hydraulics, some instrumentation and a bit of automotives mixed in, and the world is so much bigger. So with that in mind, and for the added value of the viewers, wouldn't it be at least polite to provide them some info, rather than hold back on my sake?
  18. magnet18
    Dec 22, 2010
    1,232
    125
    I remember that stuff... HATED the smell, but it did work...
  19. loosewire
    Apr 25, 2008
    1,584
    435
    @ GetDeviceInfo,,You know hydraulics Is a car jack with power,Its when more power
    Is applied that the pressure become important,not many surprises
    there until a load drop unexpectedly,a death trap. There has to be more
    oil guys on line or do you want me to fall in the well for a laugh.
    Get Info that your name. I have a loosewire.
    I do have a story to tell and It's good information
    for the uninformed.
  20. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Let'er rip
