Varying voltage from a sensor into a PIC16F887 and store it
Discussion in 'Embedded Systems and Microcontrollers' started by quantumlab, Dec 4, 2008.
  1. quantumlab
    Dec 4, 2008
    19
    i am currently trying to input a varying voltage from a sensor into a PIC and store it in its memory. I am using PIC16F887. What would be the simpliest way of achieving our goal using assembly code? I would appreciate any help. Thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Apply the voltage to a PIC pin that can be configured as an input to the internal A to D converter (assuming there is one). Convert that input as often as needed.
  3. quantumlab
    Dec 4, 2008
    19
    Thanks for the reply. What code do i need to 'convert the input as many times as needed'? What code do i need to store the values at say twice a second?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If my catalog is correct, the PIC you have has an A to D converter with 12 inputs. The relevant section in the manual for the 16F887 will tell you how to select an input pin and configure it as an input to the A to D. It will also tell you what the command is to do a conversion. After that, it is just a matter of storing the value.
    As to the time, there is another section that describes internal timer operation. Set on up to give interrupts at your desired interval. Do the conversion in the interrupt routine.
  5. boff1
    Member
    Oct 15, 2008
    26
    This is something I have done many times with a pic16f887. I use Jal compiler and can let you have code examples if you wish. I don't code in C or ASM.
    cheers
  6. quantumlab
    Dec 4, 2008
    19
    Hi i have written the following code to recieve an analog input and store it in the general file registers. I am unsure yet as to what is involved with the interupt. I would like to simulate the code on MPLAB SIM. THe code is quickbuilding succesfully but when i simulate it i get the following error:
    ADC-W0008: No stimulus file attached to ADRESL for A/D.
    The code is shown below. Any help would be great
    list p = 16f887
    #include<p16f887.inc>
    RESULTHI EQU 20 ;First counter
    RESULTLO EQU 21 ; Second Counter
    ORG 4 ; Interrupt vector address
    ORG 5 ; Start of program memory
    BANKSEL ADCON1 ;
    CLRF TRISA
    MOVLW B'10000000' ;right justify
    MOVWF ADCON1 ;Vdd and Vss as Vref
    BANKSEL TRISA ;
    BSF TRISA,0 ;Set RA0 to input
    BANKSEL ANSEL ;
    BSF ANSEL,0 ;Set RA0 to analog
    BANKSEL ADCON0 ;
    MOVLW B'11000001' ;ADC Frc clock,
    MOVWF ADCON0 ;AN0, On
    ;CALL SampleTime ;Acquisiton delay
    ;BSF ADCON0,GO ;Start conversion
    ;BTFSC ADCON0,GO ;Is conversion done?
    ;GOTO $-1 ;No, test again
    BANKSEL ADRESH ;
    MOVF ADRESH,W ;Read upper 2 bits
    MOVWF RESULTHI ;store in GPR space
    BANKSEL ADRESL ;
    MOVF ADRESL,W ;Read lower 8 bits
    MOVWF RESULTLO ;Store in GPR space
    END
  7. danieltooop
    Feb 10, 2009
    I hope this configuration picture helps you to understand deeply..
    With Regards,
    Daniel,
    Drug Rehab
  8. tpraja
    Apr 6, 2009
    Hi Tooop,
    Thanks for this circuit picture. It really help me to understand deeply. Cheers!
