Varicaps - Value is measured or calculated?
Discussion in 'General Electronics Chat' started by atferrari, Nov 11, 2010.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,666
    784
    Could not find how the capacity of a varicap (or any diode for the case) is obtained.
    Is it actually measured? I do not see how you could (?)
    Or are they used in a VFO and their capacity calculated?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    AFAIK the capacitance is a function of the bias voltage. The datasheet should have a range specified.
    PackratKing likes this.
  3. eblc1388
    Nov 28, 2008
    1,542
    102
    Varicap diodes are operated with reverse bias and thus takes nearly no current .
    The following circuit will measure its capacitance against reverse DC voltage, using a common capacitance meter.
