Hello everyone,
once again I will need your help. I have never used a variactor before but a colleague of mine insists to use one for an application. I see that mostly if not always it is used in transmitters and receivers. I am wondering though if I can use it in lower frequencies kHz range.. I see that they lack stability as they vary with voltage but I need it as a compensating component. Do you think I could use it in the 100kHz frequency? Could you recommend me one from RS. I would really like to know more about this interesting use of a reversed biased diode.
Thank you
Thank you
