Variac's
Discussion in 'General Electronics Chat' started by loosewire, May 26, 2008.
  1. loosewire
    Thread Starter AAC Fanatic!
    Apr 25, 2008
    1,584
    435
    Are variac's used in the modern electronic's world of computer's.
    Is there a need to isolate equipment and have external power suppy
    regulation from ac spike's. LOOSE WIRE
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    Varics still exist and isolation is still a requirement in some applications
  3. loosewire
    Apr 25, 2008
    1,584
    435
    What general type of equipment.
  4. nanovate
    May 7, 2007
    665
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    They are used where their is a consistent drop or excess in voltage, to bring the AC voltage into spec. Sometimes power companies aren't consistent in taking care of these problems and it is easier to use something like this to take care of business.
    They are also one of the original variable power supplies.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    At a former employer, some of the assembly technicians used variacs to control the temperature range of their heavy-duty soldering irons. Not as accurate as a true thermostatically-controlled iron, but about 1/10 the cost.
