Futurlec has them for $15.90
ICL8038 Precision Waveform Generator/VCO
http://www.futurlec.com/cgi-bin/search/search.cgi
But, they're only going to get more expensive.
But sure, the LM224N's would work fine for a low frequency signal generator. You can do a lot with them. There's a link I posted earlier on this thread to a schematic; you could modify that schematic to work with the LM224 - a one-IC multifunction signal generator. You won't run out of uses for a portable low-freq signal generator - even later on when you build or acquire a much better one, you can use your low-freq unit for modulation and other duties.
I built one that way about 8-9 years ago, but I used an LM348N (which is four LM741's in a single package) and put it in a small project box I got from Radio Shack. The circuit board was 1 5/8"x 1 7/8", the box is 3 1/4"x 2 1/8" x 1 1/8", fits in a shirt pocket. Powered it with a single 9v battery.
It's not fancy, has a freq range of 6Hz to 7Khz, 1.5v P-P output. I chose to keep the sig gen low-power to maximize battery life. You could use two 9V batteries for a +9 and -9 supply for more output voltage. Or 20 D-cells for +-15v, if you wanted that much exercise carrying it around
