I am trying to make an electronic cigarette(also known as a portable vaporizer), power supply. My goal for this project is to go from a single 18650 3.6V Lithium battery to a regulated output range of ~3.6V up to ~6.3V with 2.5 amps max draw and ~20 watts max. The 18650 batteries I am looking at using are ~2600mAh and have a 4-5 amp max constant draw. The only integrated chip I have found that gets close to what I am looking for is the PTN04050C, then I would use a potentiometer to get the desired output. My only problem with the 04050 is that it's max watts out is 12.
This power supply drives a small section of resistance wire which has a piece of wick through it to cary the liquid that it vaporizes to replicate smoking a cigarette. The atomizers come in various resistances, from 1.5 Ohm to 4.5 Ohm. Something that I would really like to include in this design is a way to check the Ohms of the atomizer. However this is not necessary and I don't even know how this would be done.
I am new to the DC circuit design field but I am very interested. All help is much appreciated. In this design I am hoping to see above 80% efficiency as this unit will be battery operated and carried around. Also the smaller I can make it the better. Can anyone help me find the DC-DC booster I am looking for?
