Variable Voltage Controller (Analogue controlled)
Discussion in 'The Projects Forum' started by ollieking60@hotmail.com, May 27, 2010.
  1. ollieking60@hotmail.com
    Feb 17, 2010
    11
    Hi
    I have a board that I need to supply with a variable supply of 5 - 15V. It needs to be a separate 'bolt on' circuit supplied with 15V, and a 5 - 15V output. However this output voltage needs to be controlled with a 0-10V analogue input. I have found lots of examples of using variable resistors to alter the output voltage, but how can i encorporate using a 0-10V analogue signal into this?
    Regards
    Oliver King
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you're only going to supply it with 15v, then you will need a buck-boost DC-DC converter in order to output a range from 5 to 15v. You would not be able to simply use a regulator like an LM317, or even a low-dropout linear regulator.
    You say you need 5v to 15v out, but at what current?
  3. ollieking60@hotmail.com
    Feb 17, 2010
    11
    I need a max current of 2Amps. I dont know what a buck boost DC DC Converter is, could you expand on that a bit please.
  4. ollieking60@hotmail.com
    Feb 17, 2010
    11
    If i supplied it with 24V, would that make it simpler?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, supplying it from 24v would only require a "buck-type" DC-DC converter.
    You would not want to use a simple linear regulator such as an LM338 due to the very high power dissipation that would result.
    Are you in the USA? If so, you might find that a pre-manufactured DC-DC converter to be an easy option. Otherwise, you will need to build a circuit.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  7. John P
    Oct 14, 2008
    1,638
    225
    If you'd rather build than buy, it should be possible.
    I picked a switching regulator more or less at random from the Linear Tech catalog:
    http://cds.linear.com/docs/Datasheet/1765fd.pdf
    The variable version of this part simply requires that you send 1.2V into a feedback pin when the output voltage is at its nominal level. Normally that's done with a resistive divider, but it should be possible to do it with an op-amp circuit that combines the 0-10V input with the 5-15V output (hedging slightly because it might not be stable). But I expect it would be OK.
  8. ollieking60@hotmail.com
    Feb 17, 2010
    11
    Thank you for your help guys. Im not in the US, but i can get hold of a DC-DC module.
    I would rather build a circuit than buy pre manufactured, so using the feedback pin on the switching regulator sounds good. However I am new to electronics, so an example circuit using op-amps to make it controllable with 0-10V would be very helpful.
